Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN MAXIMA FORUMS > 1995-1999 Nissan Maxima Gen. 4 Discussion
Google Links
» Search Used Cars
Search for used vehicles by ZIP, please enter Zipcode below:
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 03-28-2008, 06:36 PM
Coolant Leak Mystery
Hello everyone. This is my first post to the forum. I own a 96 Maxima GLE that is completely stock.
I recently noticed a puddle of coolant on my garage floor, and began investigating to find the source. It didn't take long to see that it wasn't going to be easy to track it down. After getting underneath the car and taking a look, all I can tell is that the leak is dripping down from the front lip of the oil pan. I can't see where it is actually coming from, only that it is collecting and dripping from there.
For lack of a better solution, I put some radiator "stop-leak" in, and that seems to have slowed the leak for now at least...
Any help or suggestions for tracking down the source of this leak would be much appreciated. I'm hoping I don't have to have this thing completely disassembled to find it...
I have included an image that shows as much as I can see:
Old 03-30-2008, 08:24 PM
sergey85's Avatar
Ну Погоди!!!!
one quick advice dont use that stop lleak stuff it dont work. see where its coming from i think its dripping from somewhere down to by the oil pan. you might have a blown gasket or pipe somewhere. if its coming form the oil pan its definatly not good. wipe it off clean and see where its coming from if you got access to a lift somewhere. it might just leak somewhere in the pipe but do what i said clean it well then see where its coming from. post later with more info
Old 04-22-2008, 05:57 AM
Hmmmmm... Well I guess, spring on the rad cap must have weakened over time. Installed a new one and it elliminated problem.
__________________________________________________ __
My fresh installs: buick regal muffler & buick regal oxygen sensor
Old 04-22-2008, 10:56 PM
sergey85's Avatar
Ну Погоди!!!!
yeh i dont think its as simple as that
Old 05-20-2008, 11:10 AM
Question Coolant leak
I have exactly the same problem sometimes. I only get a tiny bit of leakage after the car has cooled down overnight. Please let me know what you find out or what fixes it. I think it may be the water pump.
I changed the bottom hose and re-torqued the thermostat housing...no effect!
(it could be the gasket under the thermostat housing)
They tell me the water pump has a weep channel about 5 inches below the thermostat housing just above the oil pan. I could not find it.
Mine is a 96 Maxima GLE w/ about 75K miles.
Jim R.
Tallahassee, fl
Old 05-20-2008, 08:42 PM
First off, Stop Leak is the worst thing you can use for nissan coolent systems. Flush that stuff out right away, it clogs up the heater core!! Anyway about your coolent leak, just by looking at the location on the picture, you see coolent down by the oil pan, most likly it is the water pump. The water pump is located in the timming cover area. There are 2 small black covers on the front timming cover. One to remove the tensioner. After you remove the tensioner then the other cover is to remove the water pump. Where the wep hole for the water pump is behind the back timming cover. That is where your leak seems to be coming from, but then again, I am not actually looking at the car. Gl..
Old 05-20-2008, 08:53 PM
Cool Water pump
Agree with last post. Its probably the water pump. One last thing you might try is to tightem the thermostat housing bolts slightly Like half a flat, no more). It leaks in about the same place. I tightened mine and the leak was reduced about 50%. I plan to replace the thermostat and gasket before I jump into the water pump.
When I replaced the lower hose there was a lot of crusty build up on the housing under the hose I took off. I was thinking (hoping!) that this might have broken the thermostat housing seal also.
But I think I have a water pump problem too.
Jim R.
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
