Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN MAXIMA FORUMS > 1995-1999 Nissan Maxima Gen. 4 Discussion
Old 07-05-2009, 09:34 PM
Question Help: Engine Motor Mount Sensor
Hi ALl,
I replaced the front engine mount on my 97 Maxima with a solid rubber mount. What do I do with the sensor and/or wires to it so that my engine light will go out?
Can I connnect certain wires to bypass the sensor? If so, which colors?
Thanks,
Shortwavedave
Old 07-07-2009, 07:10 PM
Tony Two-Tone's Avatar
There's a motor mount sensor? You might want to just check the codes to see what's causing the light.
2006 Super Black Nissan Altima SE-R 5 A/T
Mods: some, but not enough. Suggestions?
In Tx? Check us out! www.teamdriven.webs.com
Old 08-02-2009, 08:58 PM
Its not a sensor. your mount uses electric current to change the stiffness (durometer) of your MM. pull your codes and see what is triggering your CEL.
Old 08-04-2009, 03:31 AM
I ordered the same borla exhaust too, and love the way it sounds it also looks very nice. I have people asking me all the time what kind of exhaust it is because it sounds so good. I got mine from borla parts here, borla 11763 and was pleased with the price a delviery time. You should also check craigslist sometimes you can find a used set.
