03 Max Burning Oil
OK, there is no drippage in the garage or driveway. No smoke when I start, no gunk in the tailpipe. The three spark plugs that are easy to check are clean. I had a compression test done on just these three cylinders, they were fine. But every 1,000 miles or so I have to add a quart of oil. The car has 106,000 miles, and this started 2 or 3 thousand miles ago.
I've had this car well-maintained, just changed to synthetic oil but no change. Previously I've changed the oil/filter every 3,000 miles.
Someone told me that this is common for the 3.5L engine - if so that's disappointing. I want to drive this car for a long time. It still drives great w Michelin Pilot Sport A/S tires. I have an estimate for a mechanic to drop a used engine with less mileage in for ~$2,000. Or I could just keep adding a quart every 1000 miles. Apart from forgetting to add the oil and causing damage, what is the downside to this option?
Reason: Adding info
