2001 nissan maxima oil leak problem - Nissan Forums : Nissan Forum
post #1 of 6 Old 10-04-2012, 07:09 AM Thread Starter
Hi everyone,
I just bought 2001 nissan maxima but Unfortunately, There was some oil leak problem with car.
I attached picture where the oil comes from.
Is there anybody to have idea , what is the problem on it.
And How much will it cost to repair ?
I will take mechanic to look up it before than I want to help from you.
Click image for larger version
ID:	34435   Click image for larger version
bluecad is offline
post #2 of 6 Old 10-04-2012, 11:42 AM
Super Moderator
4DZC's Avatar
Quoted: 373 Post(s)
iTrader: 33 reviews
That is a line that goes to the power steering pump. If the leak is coming from the line, it means there is a hole, tear, or other issue with that line, and under pressure it is leaking. It will need to be replaced. Cant be repaired, has to be replaced.
4DZC is offline
post #3 of 6 Old 10-05-2012, 09:19 PM Thread Starter
hi guyd again,
I reparied my nissan at chevron auto center,
as you said the problem was power steering horse.
they replaced the problem was power steering horse with new one and refill the fluid.
parts cost $160 and $40 fluid and lobor cost was $200 and total price got
$400.
it was unbelievable. I dont know the this is common problem
How I can avoid to face same problem again ?
bluecad is offline
post #4 of 6 Old 03-11-2013, 12:51 AM
try replacing that section with a new one
Karo420 is offline
post #5 of 6 Old 03-11-2013, 04:27 AM
the.wong.kid's Avatar
Quoted: 61 Post(s)
older cars will see these problems come around especially with hose lines. the rubber will dry/crack etc. ive replaced many 350z powersteering lines.
Sent from AutoGuide.com App
Nissan Certified Tech
05 IS300|5spd
73 240z|4spd
the.wong.kid is offline
post #6 of 6 Old 05-07-2013, 02:20 PM
The Maxima's Avatar
It just like the belts. Eventually, they'll wear down. Something you really can't avoid.
The Maxima is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN MAXIMA FORUMS > 2000-2003 Nissan Maxima Gen. 5 Discussion
