How much do ALtima 2.5S weight? - Nissan Forums : Nissan Forum
post #1 of 12 Old 12-18-2003, 08:45 PM Thread Starter
I need to get a set of Jack Stands...and some stands can hold up to 2 ton, some are 3 tons, some are 6 tons.
which one do i need? and how much do 2003 2.5s weight (I have spoiler, and convenience plus package)
Thanks.
tak
Take that!
takkie is offline
post #2 of 12 Old 12-18-2003, 08:48 PM
Member
NickM's Avatar
the 2 ton will work just fine
NickM is offline
post #3 of 12 Old 12-18-2003, 08:48 PM
enlighten me
johnmann's Avatar
2 ton will hold it.
johnmann is offline
post #4 of 12 Old 12-19-2003, 12:23 AM
Honorary So Cal Member
Hey takkie look on the inside door panel it has the weight info right there. And those will work.
dnvrfan is offline
post #5 of 12 Old 12-19-2003, 01:36 AM
Loyal Inline 4 Luver
2 tons = 4,000pds. Heck it wouldn't be a sports sedan if it weighed more than that, it would be a Buick Park Avenue. But yeah that would work fine for our car even with 3 people in it.
Altima2002V4 is offline
post #6 of 12 Old 12-19-2003, 01:54 AM
check your door panel or check nissan's website
custom catback: magnaflow 18" resonator and 14829 mufflers: UDP: 70% tint
HotBody07 is offline
post #7 of 12 Old 12-19-2003, 02:02 AM
Proud '02 owner
Nickjx's Avatar
Thats 2 tons per side. The weight raito is about 60/40. I don't know about a 2.5 but the 3.5 is about 3200 lbs. So a 2 ton rated jack stand will be fine.
02 3.5SE with a bunch of mods
Link to My Ride
vb garage
Nickjx is offline
post #8 of 12 Old 12-19-2003, 12:32 PM
The 2.5 is a bit under 3100lb curb weight. The sticker in the door is a good rule of thumb, but it does indicate max GVWR, which is max weight of the car with all fluids, passengers and luggage.
In any case the 2 ton stands will do just fine...remember that they only have to support at most half the weight of the car.
Haikus Are Easy
But Sometimes They Don't Make Sense
Refrigerator
tdoyle is offline
post #9 of 12 Old 12-19-2003, 01:59 PM
Bad Boys are Back!!!
DesiEGO's Avatar
Less than the 3.5SE
DesiEGO is offline
post #10 of 12 Old 12-20-2003, 12:02 PM
Are you crazy tdoyle? I can usually get the car balanced on one jack stand. This way I just spin the car to rotate the tires.
Anyways it is probably $10 difference to get the 3 ton, get the 3 ton, in this situation bigger is better.
3 ton are $17.99 at harborfreight.com and
6 ton are $24.99
e-squared is offline
post #11 of 12 Old 12-20-2003, 03:34 PM
Smoked Out
Originally posted by DesiEGO
Less than the 3.5SE
2005 Smoke Altima 6MT
2002 Super Black Altima 2.5S - Traded 10/21/06
http://www.cardomain.com/ride/2625220
j_archer_69 is offline
post #12 of 12 Old 12-20-2003, 05:05 PM
Old Member
omnpge00's Avatar
what does that mean. 2000 is the most a spring can handle
before it starts being depressed?
Trying is the first step to failure.
-Homer Simpson
omnpge00 is offline
