Dome Light Fuse? - Nissan Forums : Nissan Forum
post #1 of 20 Old 01-08-2004, 11:05 AM Thread Starter
Dome Light Fuse?
I was installing a new Dome Light Bulb when it seems I blew a fuse. The Dome light works when turned on, but when in the setting for it to come on when the door is open it doesnt work. I checked the fuse listed for the dome light and it is not blown. Anyone know whats the deal? Is there another fuse for when the door is open.
bhillia is offline
post #2 of 20 Old 01-08-2004, 12:07 PM
dsuave624's Avatar
It's definately not a fuse if it lights up on other settings.
dsuave624 is offline
post #3 of 20 Old 01-08-2004, 12:35 PM
Fibre Customs
altimateone's Avatar
I did the exact same thing, my dome light no worky no more either did you use something metal to take the old bulb out?
altimateone is offline
post #4 of 20 Old 01-08-2004, 01:21 PM
Bad Boys are Back!!!
DesiEGO's Avatar
Red face
Take it to the Dlr !
DesiEGO is offline
post #5 of 20 Old 01-08-2004, 04:45 PM Thread Starter
No i didnt touch it with metal but the light was in the door open its on position when i had the door open installing the new bulb. When i pushed the bulb in it blinked and I (being the little girl that i secretly am) quickly pulled it back out. Then when i put it back in it doesnt work in the open door on position. Only works in the on position.
Anyone know what it will cost at the dealer? Or how to fix it?
bhillia is offline
post #6 of 20 Old 01-08-2004, 06:17 PM
hello
iTrader: 5 reviews
It shouldnt cose you anything. Just put the old bulb back in, and bring it back. Tell them it doesnt work, they wouldnt suspect a thing, Under warranty.
fr0mastaj is offline
post #7 of 20 Old 01-08-2004, 10:32 PM
zappa_esque's Avatar
Quoted: 1 Post(s)
Re: Dome Light Fuse?
Can I ask what kind of bulb you bought ?
The dome light is drived by the BCM and I don't think they put a fuse in line with it. If there is a short, maybe the transistor driver in the BCM blow caused by bad protection design.
zappa_esque is offline
post #8 of 20 Old 01-09-2004, 07:17 AM
Hell my dome light works only when it wants too )-:
masonaltima is offline
post #9 of 20 Old 01-09-2004, 04:21 PM Thread Starter
it was a 10x31mm 10 watt bulb. It does work if you just turn the dome light to ON and it looks exactly like the original bulb. Got it from lightlens.com
bhillia is offline
post #10 of 20 Old 01-10-2004, 03:12 AM
Dome light is possesed by demons
masonaltima:
My dome lights works based on its own agenda as well. I am getting pretty tired of smacking the damn thing.
I wish I had some info on fixing it, but alas, I do not.
...And my windows automacially go down 3 inches when it's hot out.
mrdwaters is offline
post #11 of 20 Old 01-11-2004, 04:16 AM
net.altima's Avatar
my coworker had a flickering/moody dome light syndrome but went to dealer and they fixed it, it was some wiring or switch or something i forgot but its definately covered, let them fix it with your next oil change or something.
UNDER CONSTRUCTION
net.altima is offline
post #12 of 20 Old 01-11-2004, 05:32 AM
I Am My Altima's Bitch
niceorange's Avatar
You sure you didnt just leave the door open this whole time, and it wouldn't work because of the battery saver shutdown? There is no fuse for the bulb that is seperate for the door function. Basically the way it works is the bulb is powered by the battery saver output circuit from the Body Control Module (BCM), which supplies 12 V for a set period of time, then shuts off until it sees no load. The switch is actually either open (light off), ground (light on), or it connects it back to the BCM, to the door lamp control terminal, which grounds the light when the doors are open, or if they are unlocked, etc. Basically if it isnt working, the switch is probably bad. Good luck.
Crystal Blue 2003 Nissan Altima 3.5SE 5-Speed
niceorange is offline
post #13 of 20 Old 01-14-2004, 09:01 PM
Mine is doing the same thing. It worked only briefly in the "On when door is open" position when it had gotten quite cold out. Don't know if that had anything to do with it or not. At any rate... my dome light will come on when the switch is manually turned to the "on" position... but it usually doesn't work when it is in the position to come on when a door is opened. Seems silly that this is a problem. I mean... Whirlpool as been having refrigerator and oven lights come on for awhile when their door's are opened. Wonder what is so special about a car? lol.
Any way... I wish I could tell you what the problem is... but since my car is out of warranty... I don't want to spend the money to get a light fixed. I'm hoping someone on here can figure out the problem and post. I'd rather try to fix the problem myself.
bamashawn is offline
post #14 of 20 Old 01-16-2004, 09:39 PM
Just wondering if anyone has experienced this dome light not working when door is open problem (described above)... and hopefully have a solution. -Thanks
post #15 of 20 Old 11-29-2012, 02:39 AM
I have this problem and it sucks. does anyone know if it is easy to swap out your bcm?
frankyw1ld is offline
