p0301 Cylinder 1 Misfire Detected - Nissan Forums : Nissan Forum
post #1 of 29 Old 07-14-2004, 03:54 AM Thread Starter
I did the check code procedure and came up with this.
Diagnostic Trouble Code (DTC) p0301
DTC Definition: Cylinder 1 Misfire Detected
I just got the lookup from http://www.actron.com/code_lookup.php
Has anyone else had this problem? The car stumbles under acceleration. It is a 2.5s manual.
Joel W.
Random Thoughts Racing
1993 Sentra se-r (gutted)
2000 SE 2.0 5sp no PP
2002 Altima 2.5s lemon
random thoughts is offline
post #2 of 29 Old 07-14-2004, 02:56 PM
Honorary So Cal Member
No I have never had that issue come up. Sounds like that is definately a dealer issue though.
dnvrfan is offline
post #3 of 29 Old 07-15-2004, 09:06 PM
Are you using a high octane gas?
If you are using something higher then your car is suppose to have it can cause a misfire. The higher octane can cause a premature explosion while the piston is on its way down which now is working against the piston instead of with it.
Joseph is offline
post #4 of 29 Old 07-16-2004, 03:18 AM Thread Starter
Yes I always run the highest octane available in CA...91
The check engine light is now off despite my manually canceling it twice through the check/ reset code procedure. Dut there is no documentation as to how the misfire was fixed. Instead there is a note that one of the butterfly valve screws was missing... when I stated my disconfidence in having a screw travel into the motor he stated that they sometimes "go right through". I stated that 'it would have to for sure hit a valve and the piston defore becoming lodged in the pre catalyst if it even got that far! There is no way for this screw to get far enough away from the engine to not still be a significant liability of catastrophic failure!"
The car was released to me and continues to bog and hesitate above 4000k in 4th gear going uphill (yess I know this is about 80mph). I brought back to the dealership after my test for a reexamination.
Joel W.
post #5 of 29 Old 07-16-2004, 03:47 AM
carputer owns you
DJKhan85's Avatar
Woah I thought using a lower octane than your are supposed to does that. I've used nothing but 93 in my car since the day I bought it and I have never had this probelm. Now I know this has been discussed to death but int he manual it says to use "
FOR 2.5L ENGINE
UseUnleaded gasoline with an octane reading of at least 87AKI(ANTI KNOCK INDEX) number (REASEARCH octane number 91)"
Then it says for improved vehicle performance, NISSAN recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI number(research octane number 96"
now from this I gather as long as the 2.5 guys use 87 OR HIGHER they are more than fine. Hell nissan recommends 96. Now i don't see why running 91 would caue this. If i'm interpreting this wrong someone please clarify this for me
DJKhan85 is offline
post #6 of 29 Old 07-18-2004, 03:37 PM
I have code P0303 as I type this - Cylinder 3 misfire in my 2.5S (2002). I had a similar code about 2 months ago and brought it to the dealership. They couldn't find anything wrong with it. I've had so many service engine lights come on in the past 3-6 months. Everytime, I bring it to the dealership with no fix. I'm getting fed up with this car....
awilki01 is offline
post #7 of 29 Old 07-24-2004, 12:53 PM Thread Starter
Well the cat is busted up and a new motor has beel ordered. On the plus side I can have a clutch put in while the motors out at a fraction of the normal price!
Joel W.
post #8 of 29 Old 07-25-2004, 02:09 PM
Why are you replacing the clutch??
dnvrfan is offline
post #9 of 29 Old 07-25-2004, 08:26 PM Thread Starter
I am replacing the clutch because my wife learned to drive stick with this car... ;-)
Joel W.
post #10 of 29 Old 07-30-2004, 12:10 AM
Ouch^^^^
dnvrfan is offline
post #11 of 29 Old 02-21-2011, 01:28 PM
i am having the same problem with mine. i swapped coil packs one at a time and spark plugs as well. i have reset the computer and it still comes back. even replaced both O2 sensors.
nwykyankee21 is offline
post #12 of 29 Old 02-21-2011, 11:57 PM
Super Moderator
tooslow_4_u's Avatar
Quoted: 180 Post(s)
iTrader: 6 reviews
wow, talk about using the "search" feature. 6.5 yrs later it comes back
PM me for Overlay or Projector Retrofits
Originally Posted by RIZAMAN View Post
People who defend CVT are like people with ugly kids - they have no choice but to love them.
tooslow_4_u is offline
post #13 of 29 Old 02-22-2011, 02:33 PM Thread Starter
Hopefully you dont have the issue that was eventually discovered with my 2.5. Close coupled cat disintegrates and the catalyst material is sucked back into the cylinders. Also the butterfly screws in the intake were not loctighted from the factory and a few were sucked into the motor (there was a TSB on the screws and the cat). The car was eventually bought back by Nissan under Lemon Law 2 motors and 3 manual trans later we were finally rid of the turd. Nissan dragged out the process and fought us every step of the way (terrible customer service!). I will never buy another QR25 powered Nissan! Used sr20 powered Nissans are still a reliable favorite of mine though.
Joel W.
post #14 of 29 Old 02-24-2011, 04:46 AM
I'm at the point of where i think i need a new motor. no way for me to really tell until i get the car back to the states. unforntayelly that wont be for about anoher 6 months so its just sitting right now. looking for a motor to swap into it. just dont know what will fit lol. by the way, nissan in europe does not honor us TSB's (techinical Service Bulletins) so im screwed. new motor will cost 1800 for the long block, and i cna resues external parts from my old one except the cat, but im going with a header instead...cheaper and dont have to worry about the honeycomb material getting sucked back in. I hope Nissan goes Bankrupt in hte near future!!!
post #15 of 29 Old 04-26-2011, 02:47 PM
I have the same issues. Cylinder #1 and Multiple misfires and CAT errors.
took it was while a back to my local mechanic and he first replaced Spark Plugs...nothing
Then he suggested that we replace CAT and Engine Manifold. Did that, still nothing...car still shakes and SES light keeps blinking/flashing. Rough starts and it seems like something is "clogged" somewhere. Thats what it feels like when I am driving. After driving for a while the car seems to get a jolt of power and runs normal, most times, the flashing/rough ride starts again.
Going to try to replace Head Gasket and Fuel Injector, rather than buying a new motor for now. If that doesnt work, then will sell car for parts. I wont spend $1800 to $2000 on a 2003 Altima with 205K KM's on it.
Fed up with this car.
muggzs is offline
