Bad Fuel Damper - Nissan Forums : Nissan Forum
post #1 of 10 Old 07-14-2004, 07:33 PM Thread Starter
Bad Fuel Damper
anybody has any experience with the Fuel Damper going bad, how you knew it was the fuel damper , how a bad fuel damper sounds and if a bad fuel damper has any permanent damaging effects on the engine - 04 V6 Alty
franzd is offline
post #2 of 10 Old 07-14-2004, 07:36 PM
Unregistered User
RobMac's Avatar
Never heard of this term before...
RobMac is offline
post #3 of 10 Old 07-14-2004, 07:44 PM
Not So New Member
MikeB's Avatar
Man you've got some strange questions. I'd try to help you, but I don't know what this part is you're talking about. There is no reference in the Service Manual to a "Fuel Damper". The only damper is in a hydraulic circuit for the ABS/TCS systems:
<------- That's Jessica, and yes, she IS hot
My Alty's FOR SALE
Check out my ride.
MikeB is offline
post #4 of 10 Old 07-14-2004, 07:55 PM Thread Starter
well, dealership told me the have to replace that part - it causes that rattling noise after warmup
franzd is offline
post #5 of 10 Old 07-15-2004, 01:11 PM
Former Altima Owner
My3Point5SE's Avatar
this schematic looks to be about anti-lock brakes....I don't know why you're calling it a fuel damper...???
My3Point5SE
Ignore the screen name...I'm now the proud owner of a 4Point0SE (06 Frontier Crew Cab).
My3Point5SE is offline
post #6 of 10 Old 07-15-2004, 03:28 PM
It is a digram for ABS...thats what he waid in the post.
Fuel damper...I have no idea what it could be. What kind of rattling are you hearing after startup? Under what conditions do you hear it and does it go away inder other conditions?
Haikus Are Easy
But Sometimes They Don't Make Sense
Refrigerator
tdoyle is offline
post #7 of 10 Old 07-15-2004, 05:27 PM
Unregistered User
RobMac's Avatar
I'm going out into left field here but here goes anyways....
I read somewhere that our Altimas have a returnless fuel system, so I'm speculating that this so called fuel damper may be used to normalize the fuel pressure between injector pulses. If the fuel pressure is too high (spiking) the rattle that he hears could be from the injectors injecting the fuel at too high of a pressure?
OK.... I'm coming in from left field now.
RobMac is offline
post #8 of 10 Old 07-15-2004, 05:36 PM
X-Mod
LMAO. Get us the part number off the repair order, if there is one. Maybe there is such a thing.
Altimat is offline
post #9 of 10 Old 09-16-2014, 02:58 PM
Mackdaddy
Quoted: 17 Post(s)
Currently I have a problem with one of the dampers leaking and it's dripping gas on the intake manifold. This apparently isn't a common issue as I can't find a whole lot of information on it.
'06 Silver Se-R 6MT -- K&N filter on a stick -- cattman headers -- cattman 3in Y pipe -- BRM 3'' ex into dual 2.5'' -- JWT clutch & fw -- Spec V tranny with lower fd and LSD -- EGR delete -- NWP VIAS BOP -- RL mm -- RL shifter bushings ..... to be continued ...
Fuzzyknub is offline
post #10 of 10 Old 09-23-2014, 04:08 PM
Quoted: 63 Post(s)
2004 is a split year for that engine... the damper basically soothes out the fuel flow to the injectors. Your fuel pump pulses as it pumps the fuel to the rail. This smooth it out so there is a constant flow of fuel. As far as damage, long cranking times on start up, excessive wear on the fuel pump, and possible damage to the injectors ( long shot)
If you pm me a vin I will verify what style your car has,...
Chris
CHRIS
CCABE@TASCA.COM
Your source for OEM parts at employee pricing..
WWW.TASCAPARTS.COM
http://www.nissanclub.com/forums/signaturepics/sigpic225617_1.gif
TASCAPARTS is offline
