Creaking noise :( - Nissan Forums : Nissan Forum
post #1 of 17 Old 05-18-2005, 05:30 PM Thread Starter
Über
Groggy23's Avatar
Creaking noise :(
About last Nov-Dec. I noticed some creaking noise from inside the cabin towards the front wheels. Happens only every so often, now its becomming a little worse and noticable. Usually occurs when I just start her up in the morning. Sounds like a door creaking or putting stress.. Anyone encounter this problem? I just had it tuned up at the 10k miles mark about 3 weeks ago.
2004 Nissan Altima 3.5SE (auto)
Umnitza DDE DRL Wiring Guide
Groggy23 is offline
post #2 of 17 Old 05-18-2005, 07:38 PM
Spun Main Bearings
OD3X1's Avatar
Sounds like you could be hearing an ABS self test. Does your Altima have ABS?
OD3X1 is offline
post #3 of 17 Old 05-18-2005, 08:40 PM
philip_240sx's Avatar
The ABS self test usually occurs when the car is first moved after starting... usually within the first 20-30ft of travel.
- Philip A.
'03 Altima 2.5S... 5 spd, and lightly modded with Nismo ;-)
'90 240SX... in well deserved retirement
philip_240sx is offline
post #4 of 17 Old 05-18-2005, 08:59 PM
Could it possibly be the control arm? Is it both front wheels or just one side? Does it happen when the suspension cycles or just indicriminately going down the road?
jermil01 is offline
post #5 of 17 Old 05-19-2005, 12:37 AM
I just noticed that on mine too. I got a flat, actually the sidewall blew out, cheap ass bridgestones, when I jacked the car up is made creaking noises. When I lowered the jack, it made horrible creaking and groaning noises, didn't sound quite right. Sometimes when I go over large bumps or move in the car at a stop light it creaks. You think it might be the struts. I've got 23k miles on mine and its an 05. Chris
02VQ35 is offline
post #6 of 17 Old 05-19-2005, 12:58 AM Thread Starter
Über
Groggy23's Avatar
^mine isn't that bad. But yeah mine usually occurs just within the first 20-30ft of travel after I haven't driving for along time. Should I be concerned with this? I think mine came with ABS its a 3.5SE if that helps. I will look in my glove cmpt for papers.
Groggy23 is offline
post #7 of 17 Old 05-20-2005, 06:12 PM
I had a similar noise the first winter I had the Alty. It went away and never returned. I assumed it was just some dirt or corrosion in the coil springs.
- Philip A.
post #8 of 17 Old 05-20-2005, 06:21 PM Thread Starter
Über
Groggy23's Avatar
do you think it could be the struts or springs? A good excuse for me to drop my car I'll take a video tomorrow morning after it hasn't been driven for at least 10-12hrs so I can let you guys hear what im talking about. Just gotta remind myself to do it.
Groggy23 is offline
post #9 of 17 Old 05-23-2005, 05:55 PM Thread Starter
Über
Groggy23's Avatar
Ok, made a short clip of what im talking about. It becomes really apparent when I accel or stop. You will need to turn up the volume a little to hear it.
altimasound.wmv
Groggy23 is offline
post #10 of 17 Old 05-23-2005, 06:23 PM
How bout them Dawgs
Bigox911's Avatar
It it happens mostly when you accel or stop...it def. sounds like something needs to be lubed. Do you have a aftermarket sway bar?
CAR IS FOR SALE
2005 3.5 Super Black
Navigation
Custom Magnaflow exhaust 2.5"
Magnaflow 14829's
Magnaflow 27" Resonator
Berk V2
AT Grounding Kit
Unorthodox Ultra S/C Pulley
Nismo F&R sway bars
Eibach Pro-Kit
For Sale: 98-02 Honda Accord Coupe Spoiler
CLICK HERE
Bigox911 is offline
post #11 of 17 Old 05-23-2005, 08:26 PM
I totally agree, sounds like something, a bushing maybe needs to be hit with some lubricant. It's probably more annoying than anything else.
'01 GXE, bone stock
jermil01 is offline
post #12 of 17 Old 05-24-2005, 01:24 AM Thread Starter
Über
Groggy23's Avatar
I kind of got used to it but no everything is stock except for intake. I'll bring it to nissan this weekend to have it lubed whatever needs to be. Thanks for replies.
Groggy23 is offline
post #13 of 17 Old 05-24-2005, 04:13 AM
Shift_PSHHH!
doc25398's Avatar
I hbad this same problem with my car, the solution is pretty simple check your exhaust hangars. Whenever the car stops or starts or rolls i get it, because y exhaust hangars, they need to be fixed, check that. When the car is off, and the exhaust is cooled reach under the car, and try to wiggle the exhaust pipe a bit, and sree if it still makes that noise.
Alex
FOR SALE:
Turboed Altima 2.5 Check it all out here:Turboed Altima For sale/Parting out!
www.AltimaSE-T.com
doc25398 is offline
post #14 of 17 Old 08-28-2005, 04:30 AM
italysfinest327's Avatar
i have the same sound that you have groggy, i think its form the intake bc after i installed the intake it started making this noise
italysfinest327 is offline
post #15 of 17 Old 08-28-2005, 05:18 AM Thread Starter
Über
Groggy23's Avatar
whoa i forgot about this thread hehe. well actually after the accident they replaced the tirerod and strut which eliminated the creaking noise even with my berk intake on. Now I'm having intermitten problem of a squeaking noise only when I change gears from P and R...
Groggy23 is offline
