Erratic Idle - Nissan Forums : Nissan Forum
post #1 of 9 Old 07-11-2005, 05:34 AM Thread Starter
Erratic Idle
2002 Altima 2.5S has a werid idle. It has a high idle around 900rpm. In Park it'll be at 1100rpm, and if i tap the accelerator a tad it will start to increase on its own up unti 2000rpm, than drop down really fast to like 700rpm than quickly come back to 1100rpm. Seems like it has a fast idle when driving to, I can feel the downshifts when braking/slowing down. I got a Service engine soon light, so i pulled a code P0507, Idle speed control system for a high idle. To me it seems like the throttle plate needs to be lubed, but im sure thats not all, can anyone help?
crank it till it hz
speedy266 is offline
post #2 of 9 Old 07-11-2005, 04:38 PM
My little champion...
KeVQ35's Avatar
Quoted: 19 Post(s)
iTrader: 3 reviews
Did you take your car in for service lately - throttle body cleaning? This occurs normally after throttle body cleaning has occured.
Had my throttle body cleaned and idle went up and light came on. They tried to blame it on the CAI I had installed.
I had that code go on since last year December 2004, and finally go off by itself maybe about 2-3 months ago...
KeVQ35 is offline
post #3 of 9 Old 07-11-2005, 06:05 PM Thread Starter
Yah i did do a throttle body cleaning and the light came on a couple days after, i reset it, hasnt come on again since but the idle is still all werid. Im thinking that while cleaning the carbon, some was pushed over onto a sensor or something, i wanna try fine cleaning it with a q-tip and maybe rubbing alcohal this time. Than lube all along the moving part. I think maybe opening the throttle plate manually is bad? Cause i didnt use alot of cleaner, and i sprayed it on a paper towel than cleaned.
crank it till it hz
post #4 of 9 Old 07-12-2005, 02:23 AM Thread Starter
I did the Idle Air volume learning procedure and it idles as smooth as glass! Whew i was reading up on it and Nissan was suggesting new throttle bodies to some people who had the same problem i was getting scared cause its 700$, i was think theres no way a 700$ part goes bad from cleaning, theyd have some sort of prevention of that, otherwise thats just cheap. Hopefully nothing comes back. Thanks
crank it till it hz
post #5 of 9 Old 07-01-2006, 06:43 AM
man when i do the learning process my light doesnt blink
gio
geo5599 is offline
post #6 of 9 Old 07-01-2006, 06:44 AM
and after you turn on and off 5 times do you quickly press the accelerater and release or calmly do it?
gio
geo5599 is offline
post #7 of 9 Old 07-01-2006, 07:58 AM Thread Starter
Hey i'll be glad to help you out with the process, i just dont know it off the top of my head how it goes. The speed of pressing and releasing should be about 1 second. So from the start of one full depression to a full release should be 1 second. Going to slow and the procedure wont work. But dont try and do it as fast as u can either. PM if you have any more questions.
crank it till it hz
post #8 of 9 Old 07-11-2006, 05:47 AM
2much4U
hei..how many miles your car has, does it cover by the warranty?
alibudiman is offline
post #9 of 9 Old 07-12-2006, 03:32 PM
its not under the warranty does anybody think this code p0420 would be the one that i need to really fix? could that be why the idle is high. the code is a (catalyst system efficiency below threshold) along with the p0507.
geo5599 is offline
