Coolant Smell - Nissan Forums : Nissan Forum
post #1 of 15 Old 01-21-2006, 11:31 PM Thread Starter
JOEZNISSAN's Avatar
Quoted: 3 Post(s)
Coolant Smell
I have a 2005 SE with 7500 miles on her. For the past couple of months Ive noticed a coolant smell after the car has been driven for a good 30 mins. I only smell it on the outside of the car, like when I open my drivers side door that hot air the car gives off from underneath. It will only last about 2 or 3 mins after I stop driving the car.I do not smell it in the cabin, vents, engine bay, or radiator area. I have no signs of leaks on the ground or white exhaust smoke and my heat works fine. I have not brought it into the dealer because I know if there is no physical signs of a leak they wont do a thing. Any ideas what this could be? thanks
2014 3.5SL Pearl White with Tech Package
JOEZNISSAN is offline
post #2 of 15 Old 01-28-2006, 03:57 AM
Take it in, they are well aware of the problem. The radiator is splitting usually on the driverside. Mine does that too, they can't find the problem though. Chris
02VQ35 is offline
post #3 of 15 Old 01-28-2006, 04:31 AM
Berk Powered
imptrlvr75's Avatar
From what I read it is the shitty plastic end tanks.
2002 Nissan Altima 3.5 SE Sheer Silver 5sp Manual
Berk V2 WAI INSTALLED (love it)
Mods on the way: AT Grounding Kit, Trenz billet grille
imptrlvr75 is offline
post #4 of 15 Old 01-28-2006, 04:34 AM
Yup, thats whats splitting.
02VQ35 is offline
post #5 of 15 Old 01-28-2006, 04:55 AM
Velicos's Avatar
I've had two radiators go **POOF** due to the shitty plastic sections....
...damn you cheap Nissan engineering!
2009 Subaru Impreza WRX 5-Door
Velicos is offline
post #6 of 15 Old 01-28-2006, 06:52 AM
hrmmm im goingto look into this.. i have just shy of 600 miles on my 06 se-r and i smell coolant when turning off the car or running for a while...
uhh ohh what did i get myself into here
06 sheer silver se-r:
HTML Code:
http://www.cardomain.com/ride/2318913/1
97 yota camry: my camry
cam2altima is offline
post #7 of 15 Old 02-04-2006, 12:00 AM Thread Starter
JOEZNISSAN's Avatar
Quoted: 3 Post(s)
Thanks for the replies, is the end tank part of the radiator itself?..When I have some time Im gonna make an appt with the dealer to have it checked, but Ive smelt it for a good 3 months and it hasnt gotten worse and my level seems to be the same.
post #8 of 15 Old 02-04-2006, 01:44 AM
Berk Powered
imptrlvr75's Avatar
Yeah, they are attached to the top and bottom. Without them the radiator would not be sealed.
post #9 of 15 Old 02-04-2006, 05:45 AM
changeyour|gameplan
I had a radiator replaced on an 05 SE with less than 6K on it. There was a micro crack somewhere in it, and though I couldn't find the crack itself, I'd get some tiny white splatters on the black plastic. I could drive for weeks on end and never have to add any coolant, but I could smell it.
They ended up replacing the radiator and the problem went away. There were known supply issues with the radiators in some 03's? and 05's? or 02s and 05's, I don't remember... But the whole process was about 2 hours. The just hoist it, drop the radiator out from underneath, and the new one was in in no time.
Even as a detail person, I wasn't 100% convinced the radiator was cracked. The dealer offered to replace it, and I didn't complain, and for me that did end up fixing the issue.
thatchman1 is offline
post #10 of 15 Old 03-03-2006, 08:21 PM
2003 Altima SL
istungu's Avatar
My ride is an 2003 and I'm having the same problem. Is this a recall matter whereas I can just bring it in and they fix it for free. Brought the car used so I'm sure its not under warranty anymore.
istungu is offline
post #11 of 15 Old 03-03-2006, 08:54 PM
virgilio7's Avatar
no recall. is just the radiator. mine was leaking. i just replaced it.
the radiator was like 160
virgilio7 is offline
post #12 of 15 Old 03-04-2006, 01:44 AM
changeyour|gameplan
Did you get an OEM radiator, aftermarket, or used? That seems crazy cheap from what I've heard.
Did you lower it out from the bottom as the dealers do, or figure out some other way?
The dealer tried to tell me it would have been $700 if I had paid for it, so I'm interested to see if you got a crazy deal, they are crazy overpriced, or some combination of both...
post #13 of 15 Old 03-04-2006, 03:10 AM
virgilio7's Avatar
oem type made by koyo.
the one that is completely aluminum like the koyo one for the z cost 340. dealer is way overpriced.
post #14 of 15 Old 03-08-2006, 04:41 PM
2003 Altima SL
istungu's Avatar
Any other way of fixing this without having to spend the ridiculous amount of money to have it replaced.
istungu is offline
post #15 of 15 Old 03-08-2006, 05:35 PM
virgilio7's Avatar
bro. to replace a radiator shouldn't be much. max 100 bucks or so of labor.
