disconnected battery terminals car wont start - Nissan Forums : Nissan Forum
post #1 of 23 Old 04-19-2006, 10:06 PM Thread Starter
Altima Crazy!!!
I need some help here.. i disconnected the battery terminals to clean them and now the car wont start... it cranks, and the engine turns over and radio works so its hooked up.. but wont start.. it caught on a couple of times but then died... anything im missing... could this have screwed up the ECU... (2003 2.5s)
thanks for any help...
pimpin'alty is offline
post #2 of 23 Old 04-20-2006, 01:27 AM
net.altima's Avatar
pull out plugs and check em. make sure terminal is clean and on tight and no grease on them.
UNDER CONSTRUCTION
net.altima is offline
post #3 of 23 Old 04-20-2006, 01:33 AM
You'd lose.
CvlEngAltima's Avatar
Shouldn't have done anything to the ECU. Are you sure the terminals are on tight?
If the car cranks and there's power, I don't think it's the battery, though.
1999 Firebird Formula Trans Am WS.9, M6, Blue-Green Chameleon
1987 GMC Jimmy, TBI350/TH350, 10b, 6" lift, 35" tires.
Neither quite stock.
http://community.webshots.com/user/OutlawLS1
Originally Posted by Pulski
Cvl... this may never happen again, so take note of it. Thank you.
CvlEngAltima is offline
post #4 of 23 Old 04-20-2006, 01:40 AM
Erect Member
Asleep's Avatar
Quoted: 10 Post(s)
iTrader: 6 reviews
you didnt ground them out accidentally against each other did you?
check simple shit - underhood fuses and connections.
i cant see the ecu being damaged before a fuse blows though.
Asleep is offline
post #5 of 23 Old 04-20-2006, 01:42 AM
Über
Groggy23's Avatar
Check fuses, connections, ground, etc.. Retrace your step, is there anything else you did that your forgot?
2004 Nissan Altima 3.5SE (auto)
Umnitza DDE DRL Wiring Guide
Groggy23 is offline
post #6 of 23 Old 04-20-2006, 01:44 AM Thread Starter
Altima Crazy!!!
hhm thanks for the replies... got it towed to Nissan already... guy said the chips in the keys could have been disprogrammed and car doesnt recognize the keys.
Tried starting with eather (the Quick start spray), started for a second and died.. i think it might be fuel pump, although it would be a coinsidence of timing...
checked all fuses under hood and in car..... right now i just think its a matter of coinsidence that something else failed while i was doing this maintenance....
thanks for all the replies....
post #7 of 23 Old 04-20-2006, 10:03 AM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
[QUOTE=pimpin'alty]hhm thanks for the replies... got it towed to Nissan already... guy said the chips in the keys could have been disprogrammed and car doesnt recognize the keys.
QUOTE]
He's full of shiit!!
As Cvl stated..I bet you need to take a look at the terminals.....If this just started after you discon the battery........I bet you got a bad connection...and it just needs tightened up a bit. You would be suprised how often this happens......You must have a strong, tight connection
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is online now
post #8 of 23 Old 04-20-2006, 11:55 AM
If it were the chips in the keys it would never have fired at all.
I agree its something loose.
Haikus Are Easy
But Sometimes They Don't Make Sense
Refrigerator
tdoyle is offline
post #9 of 23 Old 04-20-2006, 12:32 PM
Fibre Customs
altimateone's Avatar
did you happen to turn the car on then shut it real quick anytime before cleaning the terminals. If you did you flooded it.. if you just kept on trying to start it by turning it over without giving more gas pedal it would of started. But if you kept pressing the gas and then tried starter fluid you just flooded it more. thats my guess
I doubt its a loose terminal if it turns over like normal as you say.. it just wont fire.. it have to be fuel or ignition. That would be a coincidence though for something like that to happen, but not impossible.
altimateone is offline
post #10 of 23 Old 04-20-2006, 01:36 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
Oh..it turns over..... Well floor it and hold the key..it will start
*Bumper Plugs
Garage:
*12 Quest SL
post #11 of 23 Old 04-20-2006, 01:40 PM
Erect Member
Asleep's Avatar
Quoted: 10 Post(s)
iTrader: 6 reviews
you guys need to remember that the fuel injection doesnt listen to tb input until AFTER the engine starts. ecu pulses all injectors until startup regardless of pedal position EXCEPT for WOT. wot changes the loop condition of the ecu. i cant remember though if it goes to open or closed....
Asleep is offline
post #12 of 23 Old 04-20-2006, 02:36 PM
Kenny@Infiniti Massapequa
Da Mayor's Avatar
did you try to jump start it? watch its the battery b/c i just had hte same issue a few weeks ago and replaced the battery.
KENNYATINFINITI@aol.com [lease retention manager @ infinitiofmassapequa.com][cardomain: onephatalti]
'06 G35 6MT Sedan w/ plenty of toys... '02 Altima V6 sold 8/2/06 [TSZ33.com Shift_27]
Da Mayor is offline
post #13 of 23 Old 04-20-2006, 03:04 PM
Fibre Customs
thats the problem its not firing, but its turning over. So if its turning over then the pistons are pulling air in so air is moving through the intake and fuel has got to be injecting or how else would it fire. Now if he getting fuel and its not firing then he's not getting spark.
post #14 of 23 Old 04-20-2006, 03:11 PM
Da Mayor's Avatar
when you turn the key do all the lights just go black?
Da Mayor is offline
post #15 of 23 Old 04-20-2006, 03:20 PM
You need to read the manual that came with your car. The Altima has a cold weather and flood start program in the ecu that required throttle input. The electronic throttle is active when the motor is running and while cranking the starter...its sort of like a hybrid between an old carbeurated car and a conventional fuel injected car in that you can apply throttle to assist starting while cranking, but pumping the gas with the car off won't flood it.
This is a relatively comon problem with 2.5's...not sure if the 3.5 is subject to the same flooding issues.
Haikus Are Easy
Refrigerator
tdoyle is offline
