Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5)
  #31 (permalink)
Old 09-01-2006, 04:28 AM
Vanguard's Avatar
"I hope just 50%, BWK?"
Originally Posted by Log
Sweet install BTW!! I got my mount, but haven't done the hard wire yet.
Thanks man.
One suggestion. When I installed mine I changed the bend point on the aluminum bracket so that there would be more of a drop and it would stick out less from the mirror(more rise and less run... if you will.) Just be sure to use a back-up, aluminum can be brittle.
This gave me the perfect angle and also provided enough pressure between the mirror and the detector to stop the vibration from both of them.
It made a major difference to me and also made it A LOT easier to get to the button to release and connect the detector.
Just FYI. Hope you like it as much as I like mine. Post results.
  #32 (permalink)
Old 09-01-2006, 04:33 AM
Vanguard's Avatar
Originally Posted by JohnAkaB
Didn't want to mess up my sun visor so i bought a cheap cd visor case and screw my V1 mounting bracket to there
Hey man... after looking at the angle from my visor, It might be a decent place to put your V1 but I would suggest adding another support towards the front to make it flush against the visor... that way it would be angling down towards the hood rather than up so high... It would probably keep it a little further from the heat as well.
  #33 (permalink)
Old 09-01-2006, 06:47 AM
