Originally Posted by Chlebek
If you try to perform idle air volume learn and it won't complete you could have a bad power steering pressure sensor which wont let the ecm to learn the idle thats why it idles around 1500 or jumps up and down, i replaced them before, if you unplug the p/s pressure sensor and it will compleate the Iavl there is your problem.
I actually have a P0550 code coming up which is a bad PS pressure sensor as well as a P0507 (high idle), however my situation doesn't sound as bad as the OP, but I have been struggling for a while now with a high idle issue. Every time I do the reset, it works properly while I am driving the car, but the minute I shut it off, it goes back to idling high; at this point I am done with trying the idle relearn until I replace something else.
I have been reluctant to change my throttle body, as I started to think that was not the reason.
Anyway, how hard was it to replace the PS pressure sensor? I'll PM you for more info, if that is alright with you?
