You have to find where the leak is coming from first. The fuel filler neck, gas tank, charcoal canister and lines in between all the way back up to the purge volume control valve are part of the system. When the ECM sees a small leak in the system from the evap pressure sensor it turns the light on. You need a Consult with mighty vac or a fog machine to find the leak. I would recommend taking to dealer.
Nismo CAI, CE Y-pipe, tinted windows
