How to replace starter on 2.5? - Nissan Forums : Nissan Forum
post #1 of 9 Old 09-18-2007, 04:31 PM Thread Starter
My fiancee has a 2003 2.5SL and the starter is done. I'm planning on doing the work myself - just wondering if anyone has a procedure for this or general instructions on the best way to do it. The new part will be here in 3 hours, so I have that long to figure out the best way to take the old one out. Has anyone else done this?
Thanks,
David
dbolton is offline
post #2 of 9 Old 09-18-2007, 05:17 PM
GR
carfreak67's Avatar
This should tell you all you need to know.
Nissan Service Manuals/
carfreak67 is offline
post #3 of 9 Old 09-18-2007, 06:16 PM Thread Starter
Cool - thanks for the link. Now that I have it out, I'm wondering if I diagnosed properly. The symptom is that when the key is turned, there's a machine-gun clicking sound coming from the starter, with no engine-turn. Given the sudden nature of the failure, I'm wondering if perhaps it was just a relay or solenoid. Any thoughts?
Thanks again,
David
dbolton is offline
post #4 of 9 Old 09-18-2007, 06:29 PM
GR
carfreak67's Avatar
Thanks again,
David
That noise usually indicates a dead battery. I haven't really looked at the starters on the 2.5 but I know a lot of starters nowadays don't really have a solenoid on them like in days past. They use a kind of inertia mechanism to engage the starter gear with the flywheel. I'd have to examine the starter and the circuit to give a better idea of what's wrong.
If I get a chance I'll look through the manual and post what I find.
post #5 of 9 Old 09-18-2007, 06:51 PM Thread Starter
I was leaning away from the battery, because the lights are all systems go. I have it disconnected (as is procedure when removing a starter) and it reads 12.7V. I'm hooking up to the trickle charger for the time being just to be sure.
dbolton is offline
post #6 of 9 Old 09-18-2007, 11:07 PM Thread Starter
As it turns out, you were right on. I took the starter in to exchange and they tested it - it was good. Put it back in, jumped the car, and it started right up. Swapped the battery out for a new one and it's good as new. Lesson learned!
The good news - replacing the starter's not hard at all.
Disconnect the positive battery lead.
3 clamps to remove the tube between the airbox and the throttle body. Undo the 2 clips holding the wiring loom in place.
One is attached to a bracket that holds a cable (throttle cable?). 2 10mm screws to remove the bracket.
1 10mm nut to remove the positive lead to the starter.
1 8mm screw to remove the remaining electrical connector (didn't want to break the plastic connector, so just took out the screw instead).
Top bolt is 19mm, tough to break loose. Bottom bolt is hard to get at, 14mm. Also hard to break loose. This was the hardest part for me. Then just pull it out. If I had to do it again, probably could take it out and replace it in under an hour.
Tools needed - ratchet with extension bars, 8mm, 10mm, 14mm, 19mm sockets, screwdriver (for air tube clamps), optional - mirror and flashlight to help locate bottom bolt, breaker bar with adapter to 3/8 socket (unless you're really strong).
Peace!
dbolton is offline
post #7 of 9 Old 09-18-2007, 11:45 PM
The Choc Boy Wonder
elchoccolatte's Avatar
^^^ Good Deal...
elchoccolatte is offline
post #8 of 9 Old 09-19-2007, 12:17 AM
GR
carfreak67's Avatar
Glad you got the car up and running again.
Thanks for the write up on the replacement, I'm sure a few 2.5 owners will find it useful.
And at least it was a little cheaper fix than a replacement starter.
post #9 of 9 Old 09-19-2007, 03:25 AM
Long Time Caller
nissan2k2's Avatar
I was going to do mine, b/c my rough start was doing a number on it. But then it started working fine.
Yeah, and machine-gun clicking sound coming from a starter is almost a dead give away to a weak battery on almost any car. The starter needs a lot more juice than your lights and things, and while it is turning, if it doesn't have enough power, it will make that noise.
Congrats on the fix.
2002 Altima 2.5S
1992 NX2000
2003 Buell XB9S
nissan2k2 is offline
