How do I find radio codes to reset radio? - Nissan Forums : Nissan Forum
post #1 of 3 Old 01-13-2008, 12:26 AM Thread Starter
Ever since I had to jumpstart my car, I have had no radio even after checking the fuses, they are good. Any suggestions?
blackone is offline
post #2 of 3 Old 01-13-2008, 04:16 PM
I take PayPal donations
DryHeat's Avatar
Well there aren't any reset codes for the radio, soooo if you say the fuses are good...
Did you check all the fuses?
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
BOSEģ SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
'05 Altima SE-R
'09 Honda Odyssey EX-L w/RES
DryHeat is offline
post #3 of 3 Old 01-13-2008, 05:04 PM
Videogameaholic
i think he's talking about the anti-theft code.
mine was on a card in my manual lukily the previous owner left it in there.
You have to take the car to Nissan dealer to get the code for you radio. and they will most likely charge you as much as it would cost to have an after market BETTER stereo professionally installed.
dontcrossme is offline
