Need help Changing Spark Plugs!!! - Nissan Forums : Nissan Forum
post #1 of 8 Old 05-06-2008, 08:56 PM Thread Starter
I am currently at 40,000. Not sure if changing them now would improve fuel economy much. I own a 2.5s 2006 altima.
How difficult is it to change spark plugs? Where are they located. I can't seem to find them
goldenlight is offline
post #2 of 8 Old 05-06-2008, 09:15 PM
Shaving My Shoulders
RIZAMAN's Avatar
Quoted: 257 Post(s)
If you have a 3.5, you have platinum plugs, and you do not have to change them until 100K...
When you are ready to change them (3.5) - you had better do some reading, or get some help - the rear bank is a real bitch to get at (you have to remove the intake manifild, among other things).
Read this...
Then read this...
Not sure if the QR25DE has platinums...
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
Originally Posted by Penguinchit View Post
All you G owners suck balls.
RIZAMAN is online now
post #3 of 8 Old 05-06-2008, 10:13 PM
Registered Alti Pilot.
Arod0079's Avatar
2.5 calls for a replacement at 100k with i think iridium plugs. I would assume platinums would work just as well. I just forked out 50 bucks on a set of plugs.
Aaron
2002 Nissan Altima 2.5S Polished Pewter http://www.cardomain.com/ride/2950931
Arod0079 is offline
post #4 of 8 Old 05-06-2008, 10:19 PM
Fibre Customs
altimateone's Avatar
Changing plugs on a 2.5 will be real easy. I thought before clicking on your thread that you had a 3.5. Not as easy on the 3.5.. I think Nissan says you never have to change your plugs. But since its easy to do on the 2.5 it can't hurt nothing.
altimateone is offline
post #5 of 8 Old 05-06-2008, 10:33 PM Thread Starter
I want to increase my fuel economy.. Will this help.. Or can I make things worse.
post #6 of 8 Old 05-07-2008, 01:35 AM
Quoted: 2 Post(s)
i dont have the four i have the six, but to answer your question the spark plugs should be under the coil packs on the valve cover. at only 40k miles it probably wont make a difference if you have the platinum plugs. if you have the vpower you might want to change them. just change your air filter and keep your tires inflated properly.
tripod is offline
post #7 of 8 Old 05-07-2008, 02:55 AM
BT
Super Modder
BT's Avatar
Quoted: 6 Post(s)
iTrader: 16 reviews
The stock plugs on the 2.5 are located under the individual coil packs, and are really easy to change. OEM plug is an NGK platinum design. I pulled the ones in my '04 @50k, and there was no wear on them at all. I had new ones to compare them. I'd go with the factory change interval @ 100k.
Frankensteined 2002/3/4 3.5SL
QR to VQ swap
Other Pics
My NC Garage
My Feedback Thread...
BT is offline
post #8 of 8 Old 05-07-2008, 02:52 PM
bSER272's Avatar
If you can't find the spark plugs on the QR, maybe you shouldn't be trying to replace them yourself.
'05 Altima SE-R Super Black
Debadged | TEIN H Tech Springs (front)| Racingline Springs (rear) | UR Sc Pulley | Front MMI | AEM CAI | CE Downpipe | Mossy Cat-Back | AT Grounding Kit | AT S5 Grill | Axxtion STS | VIAS Mod | NWP Phenolic IM Spacers | IM P&P | Technosquare Reflash | Racingline FSTB | Racingline Rear Endlinks | Racingline HFPC
bSER272 is offline
