Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5)
Google Links
» Search Used Cars
Search for used vehicles by ZIP, please enter Zipcode below:
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 05-21-2008, 06:00 PM
jessedang's Avatar
S-AFC II help!
I would post this in another section, but I thought it'd get more attention here.
I just recieved my Apexi' S-AFC II from OfourVsix (Miguel) and there were no manuals or diagrams included so I had to do some research. I ended up taking out the glovebox and part of the dash to expose the ECM. Struggled a little bit with the black and white clips but got that off and I bought some easy wire splicers from RadioShack to connect it but I wanted to document and clarify a few things before continuing with
I found that the Apexi' N8-C is the correct diagram for my 04 4AT 3.5.
I have a few questions:
Does anyone know which wires on the S-AFC II correspond to the pins shown on the diagram? Basically what is the color codes for the S-AFC II wiring?
Here is the diagram for reference.
Thanks guys!
Old 05-22-2008, 01:01 PM
jessedang's Avatar
SAFC-II Wire Color-ECU Pin #-Function
White wire -- MAF Signal Input from MAF
Yellow wire -- MAF Signal Output to ECU
Grey wire -#73- Throttle
Purple wire -#71- Knock Sensor
Green wire -#34- RPM Signal
Red wire -#110- Power
Black wire -- 2nd Ground
Brown wire -- 1st Ground
Ground is Pin #48 and Airflow signal is Pin #61 but there is two wires for each. Am I supposed to connect both of these to the same pin? Thanks!
Old 05-22-2008, 04:25 PM
proendo's Avatar
I have not done mine yet but this was the only info I have for mine
See where it says
"cut wire to ECU, connect yellow. Connect white to the other end"
"connect brown wire closest to ECU, Connect Black 1cm away from brown wire."
CarDomain
Old 05-22-2008, 04:30 PM
jessedang's Avatar
Thanks alot, that diagram by Jime explains all of this.
To clarify for anyone reading the thread the Brown wire is closest to the ECU and the Black wire is 1cm away on the ground wire.
For white and yellow wires it says to cut wire to ECU and connect it to yellow and white connects to other side.
Old 05-22-2008, 04:34 PM
proendo's Avatar
Sweet! Let me know how it goes...
Is there a way to simply install it but not allow the device to make any changes... Its not Installed and I have not even turned the unit on... but I want to make sure when I do turn it on it doesn't try and map my fuel right away.
Also did you do this with the Negative to the battery off?
CarDomain
Old 05-22-2008, 05:12 PM
jessedang's Avatar
Just attempted to start with the Power Wire first. I disconnected the negative battery terminal.
I first orientated myself and counted pins so I could tell which way to look at it.
I used the quick splice clips, then connected it to the power and turned on the car thinking it would power on the SAFC II but it didn't do anything at all, lol.
I found some information from shyestparks back in the day.
turn the car on but dont start, then input the following: sens. type-hot wire, sens. # 26, 1 in and 1 out, # of cylinders- self explanatory, throttle- ascending; then turn the ignition off( this will save all your input in the memory); then restart the car again, go to settings, choose knock setting, set #1 by revving the engine 1500 (between 1300-1600 if you want) until stable then press the middle button to the right; go to #2 rev engine to 3500(between 3300-4000) until stable then press buton to the right; when finished go to monitor mode and check if there's an x by the knock sensor value; if there is none you are done with the initial set up, if there's an x repeat the knock setting again(that means you didn't do it right); of course all the fuel values have to be on default(zero) until you bring it to a shop to have it tuned, or you have a preset map( not recommended).
PS: it is N8-C ( if you have a manual tranny, you'll need to open your wiring harness and stick a wire in pin out # 34(tach signal).
Old 05-22-2008, 05:41 PM
hacku's Avatar
Supreme Being
Just read this and sounds like you already have your answers...
Good luck with the tuning. Do you have a wideband controller?
Old 05-22-2008, 05:47 PM
jessedang's Avatar
Oh, I forgot to plug in the ground wires, haha. No, I don't have the wideband controller.
I am going to take it to a shop and have them dyno tune it. Do any of your SAFC-II owners know how to change between the default map and map 1 and map 2? I am asking because Miguel has two maps from his car saved on the piece but I want it to run the stock maps. Thanks!
Old 05-22-2008, 06:17 PM
hacku's Avatar
Supreme Being
I know how to change them but not off the top of my head... lol
But you definitely want to reset those maps before you even drive the car. I think APEXi has the manual in PDF format on their website...
Old 05-22-2008, 07:16 PM
jessedang's Avatar
Plugged everything in but airflow and I thought I'd try it, lol..
Gave me an SES and then it revved REAALAAALALALY slow
Unplugged everything and SES is still on but car runs fine.
Old 05-31-2008, 07:08 AM
ojeda112's Avatar
See where it says
Is this the same for the same for the 05-06 Altima?
Old 05-31-2008, 03:32 PM
jessedang's Avatar
It is not the same for 05-06. Velicos made a diagram for the 05-06, look around for it.
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
