How to add refrigerant - Nissan Forums : Nissan Forum
post #1 of 11 Old 05-30-2008, 06:40 PM Thread Starter
Hi Guys,
Have any one have added a refrigerant to the air conditioner unit? Mine is blowing warm air now and thinking about adding a refrigerant to it but never done it before. Any written up procedure or pictures are appreciated.
2003 Altima (AT) 3.5 SE
JohnyKing is offline
post #2 of 11 Old 05-30-2008, 08:14 PM
TheDesertFox1942's Avatar
I dont know if you can even buy that and add it yourself!
I know it used to be, but they stopped allowing people to do that on their own years ago, enviromental reasons and all.
http://www.nissanclub.com/forums/auto-detailing/270854-how-my-car-looks-after-6-years-8-months.html
TheDesertFox1942 is offline
post #3 of 11 Old 05-30-2008, 08:39 PM
scorpio02150
scorpio02150's Avatar
Quoted: 12 Post(s)
Theres an ac tube on the left, upper side of the engine bay. Ive never done it myself, but I did see my buddy do it on his max. Its like adding air to a tire almost...Around here, you can find the refill cans @ almost every parts store.
2013 Infiniti G37x
2004 | 2.5: Brembo Rotors | Akebono Pads |Michelin Energy on stocks|
2002 | 3.5- Car Sold- some parts are available for sale!
Stillen FTB | NWP VIAS Plate | Idle Time Advanced +2 |NGK Plugs |
Berk WAI w/ Apexi | Brembo Rotors | Akebono Pads | 35% Tints |
Eibach Pro Kit | KYB GR2 | Energy Suspension Bushings | RL Rear End Links|
AT S2 Grill | AT Lower Grill | CF Tails | Custom Altima Step Plates |
BT Aux Input | BT Trunk LEDs | 8000K Headlights | 6000K Fogs |V- LEDs |
Optima RedTop | Falken Ziex 912s on stock | 18s RH Evos w/ Pirelli P60s |
Magnaflow High Flow Catalytic Coverter|
Many items are for sale!
1997 Altima: Sold
scorpio02150 is offline
post #4 of 11 Old 05-30-2008, 09:09 PM
ankit's Avatar
Quoted: 5 Post(s)
You should probably make a trip to the local AutoZone. I'm sure they will be more than happy to point you in the right direction on which kind to buy and where to put it. I didn't know they actually come outside for reasons other than windshield wipers and new battery installations but last time I went the employee was installing a whole K&N WAI into a mustang. I'm sure they wouldn't mind a tip.
Originally Posted by carfreak67 View Post
Let's get this straight.
You're an Indian and I'm an Indian.
Difference is that you're the 7-Eleven kind and I'm the alcoholic kind.
[Apu]Thank you, come again![/Apu]
ankit is offline
post #5 of 11 Old 05-31-2008, 03:36 AM
Registered Alti Pilot.
Arod0079's Avatar
Mine was blowing kinda warm last year. I just went to Wal-Mart and and got a recharge kit. It was like 20 bucks and it even came with a tube that hooks to the AC and guage to let you know when the system was full. It's blowing colder than ever.
Aaron
2002 Nissan Altima 2.5S Polished Pewter http://www.cardomain.com/ride/2950931
Arod0079 is offline
post #6 of 11 Old 06-01-2008, 01:09 PM
UzumakiNaruto's Avatar
Quoted: 8 Post(s)
is it easy to refill? i've seen those kits at walmart and was always curious about them.
Altima 2013 2.5 SL
Mods: Racingline front strut bar, BT Led footwells front and back, Led Bar Truck lights, white/yellow switch parking lights, LED's license plate lights, LED Foglights 6000k 20watt,Installed led DRL's ,Front Stillen Lip (paint matched), Enkei T6S 18 in, Retrofitted Headlights black out with s2000 projectors.
Next mods : Mud guards, short Ram intake, 8 inch Android Radio
Chemical Guys and Mothers products to keep it clean.
UzumakiNaruto is offline
post #7 of 11 Old 06-01-2008, 08:07 PM
search you n00b!!!
pipeline's Avatar
i think my condenser is crapping out..........
Originally Posted by altimatelyebony09 View Post
And damn those are some big rotor thingy magigies.
pipeline is offline
post #8 of 11 Old 06-01-2008, 10:18 PM
I tried this today and thought I was going to die. The top of the can blasted off and gas started spraying out of the can. I threw it so that if it blew up I wouldn't end up in the hospital, and the second it hit the ground, it basically burst and sent shrapnel flying in all directions. I took it back to AutoZone (in aluminum pieces) and they gave me a refund. THEN, stupid me, I bought another bottle and tried it again. Neon green liquid started to come out of the piping before I realized that it was coming OUT of my car. I'm scared to death of doing this and might take it to my local mechanic and get HIM to do it for me
2004 Nissan Altima 3.5SE
Modifications
Injen SP1978 Cold Air Intake with Hydroshield
Projector Halo/Angel Eyes Headlights and Fog Lights
Racingline FSTB
Passport Escort 8500 X50 Hardwired
JDM Grounding Kit
Debadged & 20% Dark Tints All Around
Originally Posted by madsen203 View Post
I can get 30 mpg in the city. You have to accelerate and don't let your car get over 1800RPM. It should take you around 1 minute to get to 40MPH. That is how you know you are getting excellent gas mileage.
stewiee is offline
post #9 of 11 Old 06-01-2008, 10:22 PM
search you n00b!!!
pipeline's Avatar
does not sound good..............
pipeline is offline
post #10 of 11 Old 06-02-2008, 06:56 AM
3.5 SE...Recognize
06ALTIMA-SE's Avatar
There is a product called red tech you could charge your ac system with but I recommend taking it to a refrigeration tech.
If your system is low then you probably have a small leak that can be detected by removing the remaining refrigerant and charging the system with nitrogen. This allows the system to pressurize to operating pressures and soapy water can then be used to detect leaks in the system.
06 Altima 3.5 se
AEM C.A.I.
Magnaflow mufflers
12" resonator
2 degree timing advance
6000k x light hid system
06ALTIMA-SE is offline
post #11 of 11 Old 06-02-2008, 07:46 AM
I was able to check my pressure today and it showed that it was in the "normal" range (had mechanic do this, I'm no longer touching anything having to do with pressurized cylinders). However, my A/C isn't as cold as I'd like it to be. BTW, don't get the liquid Freon gas on your hands. You'll know it isn't good to touch because it's a nasty neon green.
Modifications
Racingline FSTB
JDM Grounding Kit
stewiee is offline
