2002 Altima 3.5 Coolant fill ??? - Nissan Forums : Nissan Forum
post #1 of 6 Old 07-26-2008, 11:32 PM Thread Starter
Can't seem to find this info anywhere.
My car has 130k miles on it.... I finally want to get my a$$ in gear and flush the coolant.
Service manual says to use a vacuum tool to refill the coolant, which I don't have.
Is there any other way to refill the coolant... Like a air-release valve on the engine or something?
virtualo is offline
post #2 of 6 Old 07-27-2008, 12:27 AM
TheDesertFox1942's Avatar
You meaning to say that you never had the coolent flush and the car has 130,000MILES on it, you Kidding me RighT?
http://www.nissanclub.com/forums/auto-detailing/270854-how-my-car-looks-after-6-years-8-months.html
TheDesertFox1942 is offline
post #3 of 6 Old 07-27-2008, 04:55 AM Thread Starter
Hahaha, NOPE, I havent gotten a chance to... I've been living in an apartment with NO HOSE... and Didn't want the service station doing it for $70 ripoff. Wanted to do it myself.
Just bought a house and have a driveway and a hose now, so want to get this done now.
Iv'e done this on other cars and there was usually a cap to release the air when the coolant is filled... Service manual says to use a vaccuum system... Need to know how to so this on my own
virtualo is offline
post #4 of 6 Old 07-27-2008, 07:39 PM
20s because size matters
Your a lil late, but I guess if you have not had a problem then you are fine. I took pics when I did mine and been meaning to do a write-up, but can't find my cord to upload the pics.
First of all: coolant is hot, don't get burned.
Drain the coolant at the bottom of the radiator. Careful with the plug, it is plastic and can cross thread or strip easily.
Refill with distilled water and let the car run and get up to temp. Drain and refill till you have nothing but clean water come out.
The cooling system hod a bit over 2 gallons. So when you do the final refill add cooant to the radiator. Add 1 gallon. Run and let it mix.
You could always test you mix afterand make sure you have a 50/50 mix.
Now I switched to Toyota red. If you do something like that then you have to clean out the overfill bottle.
I will someday do a much better right up. Hope this can help you till then.
Suicidalspd99 is offline
post #5 of 6 Old 07-29-2008, 05:53 PM
get the air out
I just flushed out the cooling system on my 02 3.5SE. After you fill the radiator you need to "burp" the system. Without the vac setup you just have to keep the reservoir filled with 50/50 mix and let the engine warm up and cool off a few times. Keep the heater on to let the coolant flow through the core. You will hear the water running through the heater if there is still air in the system (I had to raise the engine RPM to about 1200-1500 to hear it).
train67 is offline
post #6 of 6 Old 07-29-2008, 08:32 PM Thread Starter
Thanks ALL for the replies.... I flushed the collant and added new... Seemed to go ok....
Next I have to take off my old slotted/cross drilled rotors and put my new ones on with new brakes. I am going back to stock on this car. Also putting my original springs back on.
So if anyone needs eibach sportlines, slotted/drilled rotors, or 19" rims,, and close to NJ, let me know...
The rotors need to be cut, the springs are used, but good... And one of the rims has a crack (not outside finish, but inside facing car) and doesnt hold air... Would need to be fixed/replaced.
mark@pcfx.us
virtualo is offline
