weird noise after oil change - Nissan Forums : Nissan Forum
post #1 of 13 Old 08-20-2008, 06:42 AM Thread Starter
08 3.5sl super black
altima128's Avatar
this is kinda weird but i changed the oil on my friends 2005 3.5 se-r and he had the old oil in their for a long time i mean over the standard 3k he had it in for 5k on conventional oil the oil was bad. well i changed it with mobile 1 high performance and a mobile 1 filter and then after we took it for a drive and it sounded raspy like as if somethings wrong. now i thought maybe i did something wrong so i took it to a mechanic and he said everything was fine but just incase we had change the oil and he said the tire rack was loose so he tightened that up but it still makes a raspy noise when you accelerate. anyone know what the problem is? its been like this for 2 months
altima128 is offline
post #2 of 13 Old 08-20-2008, 07:16 AM
2010 2.5s Sedan
jimnolimit's Avatar
where is the noise coming from ?
does it happen all the time ? or only when driving ?
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
jimnolimit is offline
post #3 of 13 Old 08-20-2008, 07:29 AM
Still #1
Leathe of Heaven's Avatar
iTrader: 24 reviews
Exhaust leak maybe?
2011 Mazdaspeed 3 current
'03 Volkswagen Passat 1.8T sold
'08 Titan 4x2 sold
'02 Altima 5MT sold
'02 Altima 4AT sold
'96 Pathfinder 4x4 sold
'83 280ZX-T sold
Leathe of Heaven is offline
post #4 of 13 Old 08-20-2008, 07:45 AM
02altima2.5s's Avatar
heat shields?
02 altima 2.5s -- 8k HID, CAI, Grounding kit, LED mirror covers, LED door handles - gone but not forgotten
1996 toyota supra tt -- Blitz boost controller, HKS front mount intercooler, HKS Intake, HKS 4-inch catless TBE, HKS coilovers, Viper 2-way alarm. EBCS set to18psi. 395/410 WHP/WTQ Pride and joy
2003 Subaru Wrx -- 05' STI 2.5L shortblock with WRX 2.0L heads, Evo3 16G turbo, walbro 255lph fuel pump, 800cc modded stock injectors, Turbo XS catless TBE, TurboXS bov, ,STI intercooler and sprayer, 17in Rota Subzeros, Viper 2-way alarm. 348/352 WHP/WTQ
02altima2.5s is offline
post #5 of 13 Old 08-20-2008, 07:55 PM Thread Starter
altima128's Avatar
it sounds like its from the exhaust you can hear it whenever you drive also he got his exhaust changed last week and got his flex pipes replaced but it still makes the noise
post #6 of 13 Old 08-20-2008, 07:58 PM
hello
iTrader: 5 reviews
Did he change only cat back, or everything? On my 02 3.5, i had a metal rattle during acceleration for a few months, and i eventually found out that it was a heatshield became loose due to rust on the Y pipe. I would take a look under there, to see if its anything obvious like mine was.
fr0mastaj is offline
post #7 of 13 Old 08-20-2008, 11:41 PM
Majestic '06 3.5SE, 5 spd
froedrick's Avatar
Quoted: 1 Post(s)
Doubtful if the O/C had anything to do with it. I'd say heatshields too.
Traded 10/10/11 for a 2012 Hyundai Genesis Track Coupe.
froedrick is offline
post #8 of 13 Old 08-21-2008, 06:22 AM Thread Starter
altima128's Avatar
he changed it just from the catalyst back he had to change his flexpipes because he busted one of his cat converters on a pothole but it mite be the heatshield how would i check that like where is located exactly because it could sound like something stuck in the heat shield since its only weird when he drives
post #9 of 13 Old 08-21-2008, 04:02 PM
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
It's fairly easy to see, big piece towards the center front of the car on the Y.
nismos14 is offline
post #10 of 13 Old 08-22-2008, 06:08 AM
Quoted: 1 Post(s)
The 3.5's have problems with the exhaust gussets breaking. Look under and you should see one on the bank 1 primary catalyst, connecting from the aluminum oil pan to the B1 primary catalyst. The second one is on the bank 2 catalyst (towards the front of the car) and bolts to the aluminum oil pan, it is curved, the other is relatively straigt. If you see a brown rust crack alltheway through. That may be your problem. Also the 3.5's have a problem with the B1 (firewall) primary catalyst heat shield breaking loose at the spot weld. You can try and have that one repaired but we replace the cat. If it's the gussets, there is a TSB (not recall, it tells us how to fix it only) with fix parts. The gussets are not connected in any way to the y or flexpipe.
PbLead is offline
post #11 of 13 Old 02-09-2009, 06:30 PM
I have very light raspy noise under certain load around 1500-2000 rpm on drive only(2.5S). No noise on park/reverse gear. The flex pipe is still good and all bolts are tight. The noise is getting worse after the engine is warm but weaker during the rain (wet road).
rondhol is offline
post #12 of 13 Old 02-12-2009, 08:22 PM
Prepare to be VQmized
Ctrl-Altima-Del's Avatar
Firmly tap on different parts of the exhaust with a rubber mallet to isolate rattles in heat shields, pipes, hangers, couplers, catalyst monoliths, resonators, mufflers, etc. It should be pretty easy to isolate that way.
'14 Tundra DC SR5 TRD 5.7l Avg MPG 17.6MPG
Traded : '03 Altima 3.5SE MT Avg MPG 26.423mpg 325000KM
Ctrl-Altima-Del is offline
post #13 of 13 Old 02-26-2009, 03:58 AM
I tapped all the heat shields and cannot find the source. the sound is like old hard drive in old computer. Only on drive and reverse with light load at arround 1500 rpm. More pronounced when engine is fully warmed up. Timing chain and tensioner are in good condition.
rondhol is offline
