How to replace thermostat on 3.5 - Nissan Forums : Nissan Forum
post #1 of 8 Old 09-09-2008, 02:41 PM Thread Starter
Question How to replace thermostat on 3.5
Great forum. Searched all t'stat threads but could not come up with any on how to get the t'stat out of the engine. I have a t'stat that is open so I purchased all of the parts needed to replace the unit, but when I got to actually trying to get it out I was stumped. Seems there is not enough room to get at the bolts and then pull the unit out without somehow raising or lowering the engine. Anybody that has done this, please let me know the trick. Thanks for all replies.
2002 Altima, 3.5, stock
johnnyk is offline
post #2 of 8 Old 09-09-2008, 11:18 PM
I take PayPal donations
DryHeat's Avatar
Download a Service Manual
'05 Altima SE-R
'09 Honda Odyssey EX-L w/RES
DryHeat is offline
post #3 of 8 Old 09-10-2008, 01:00 PM Thread Starter
Question
I do have the service manuals and the procedure is straightforward if the engine is out of the car. The problem, however, is that with the engine in the car there is virtually no room to access the bolts, and because of the length of the thermostat housing, if you did get the bolts out you will still not be able to get the thermostat housing out. It looks like you have to remove/loosen the engine mounts and rotate the engine somehow. Looking for anyone who has done this who can give me some help. Thanks, John
johnnyk is offline
post #4 of 8 Old 01-01-2011, 02:34 PM
agent22's Avatar
I have the same problem. im trying to change mine now but its a PITA to get to the bolts.
2011 Nissan Altima 3.5 SR - llumar CTX tint(30% front and 15% rear) and avery nano fusion clearbra(bumper, hood, mirrors, fenders)
2005 Nissan Altima 3.5 SE -
Nismo exhaust/y-pipe/ HFPCs/cross drilled & slotted rotors /gransport6 carbon ceramic pads/Transgo shift kit with sonnax valves/ 235/55 17 Yokohama s-drives
waiting to install: racingline MMI
agent22 is offline
post #5 of 8 Old 01-01-2011, 02:54 PM
edjose17's Avatar
you will be able to get it out if you remove the relay box and bracket in front of the thermostat housing
EdJose
edjose17 is offline
post #6 of 8 Old 01-02-2011, 12:45 AM
agent22's Avatar
yeah i did that and removed the coolant overflow tank. it was wayy easier with that crap outta the way.
had 2 fill up about a gallon of coolant and water 50/50 mix after.
went to advance auto and cleared out my p0128 DTC and it has not came back.
agent22 is offline
post #7 of 8 Old 01-02-2011, 12:19 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
Just a tip....OEM thermostat at dealer was about 10 bucks...Everywhere else it was 40+. Go figure
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is offline
post #8 of 8 Old 01-02-2011, 12:52 PM
agent22's Avatar
yeah everywhere was about $40 bucks. thats why i got mine from napa auto it was $16 with a new sticky gasket and inlet tube . also i looked at warranty for it. napa offers a lifetime warranty against defects. that is much longer than others 1-3 year warranty.
agent22 is offline
