Does anyone know if the oil pan drain plug is the same size as the automatic trans pan drain plug? Can they be used in interchangeably?
I have a 03 3.5 SE
I couldn't tell you for sure, but I seem to remember the opening for my tranny pan being slightly larger than the one for the motor oil pan. I know for sure that the plugs themselves are a different shape.
i am pretty sure they are not.. the oil plug uses a 14mm hex socket to remove, and the transmission plug uses a forget what size hex head tool to remove.
