HELP!! Power Window Reset? - Nissan Forums : Nissan Forum
post #1 of 13 Old 10-07-2008, 12:18 AM Thread Starter
Can someone tell me where the button to reset the power window on the drivers side is? It is going to rain and my window is in the down position!!
I have the panel off, but I cant find any button.
SK-1 is offline
post #2 of 13 Old 10-07-2008, 12:47 AM
I take PayPal donations
DryHeat's Avatar
1. Raise the glass to the top position.
2. While pressing and holding the reset switch, lower the glass to
the bottom position.
3. Release the reset switch. Verify that the reset switch returns to
the original position, and then raise the glass to the top position.
CAUTION:
Do not operate the glass automatically to raise the glass to the
top position.
'05 Altima SE-R
'09 Honda Odyssey EX-L w/RES
DryHeat is offline
post #3 of 13 Old 10-09-2008, 07:12 PM Thread Starter
CAUTION:
top position.
Thanks DryHeat. Mine is stuck in the lowered position, but I tried this anyway and got zero results. Owell, I tried. It is going to the dealer. Time to pull out the wallet.
SK-1 is offline
post #4 of 13 Old 10-09-2008, 07:55 PM
saywat?'s Avatar
Quoted: 22 Post(s)
i dont get it..it says to somehow raise the glass..then use the switch to lower it then raise it again?..im confused..
"Sorry Gramps, My Altima's Nicer Than Yours"
"I would like to apologize in advance for being brutally honest!"
MODS:
- Cargo Net retrofitted in the trunk
- 10w HID Converted Dome Lamp
- 8w HID Converted Door Lamps
- Removed OEM FogLight Covers
- Relocated "Special Edition" badge
- Custom Floor Mats with visible "Special Edition" Logo
saywat? is offline
post #5 of 13 Old 10-11-2008, 05:58 AM Thread Starter
Dealer Deal
Well, I took it in and after about 3 hrs, they called me back with the line, "Nissan must be very proud of that part (window motor) because it is $335.00
$532.00 installed.
I said "I don't think I would be proud of a part that worked for 4 years and broke with no warning."
He said he would call me back in 10 min. So 5 minutes pass and he calls with a new quote of $175.00 installed. I said do it.
I know I could have don it cheaper myself, but what the hell, my time is worth something.
SK-1 is offline
post #6 of 13 Old 10-11-2008, 06:42 AM
litehazelbandit's Avatar
Quoted: 11 Post(s)
Wasnt there a method of doing this without opening the door panel or pressing any reset button?? I remember it being as simple as rolling it up, holding it and then rolling it down again
2010 2.5 SL
My Ride Thread
litehazelbandit is offline
post #7 of 13 Old 10-11-2008, 08:31 AM Thread Starter
That is if the motor just needs re-set. This one was fried. I tried, and the dealer tried the reset and other "tricks" as he put it, but to no avail.
SK-1 is offline
post #8 of 13 Old 07-16-2010, 09:18 PM
06 2.5 special edition
pickup1's Avatar
Quoted: 11 Post(s)
wheres the reset switch?
pickup1 is offline
post #9 of 13 Old 07-18-2010, 02:47 PM
TorontoTunerSyndicate
Hydrolikz's Avatar
+1?
Hydrolikz is offline
post #10 of 13 Old 07-18-2010, 05:13 PM
dvo2's Avatar
That much for a motor installed? Damn. And even worse that they tried to charge 500 bucks for the install the first time. I would've told them to eat one and give me back my car to do it myself.
Originally Posted by TUKO316 View Post
Cheerios are for pussies.
I eat wheaties. Hence the reason I'm full of win.
95 Honda Accord lx Sold
05 Nissan Altima 2.5s Auto
03 Acura RSX base 5spd
dvo2 is offline
post #11 of 13 Old 07-18-2010, 08:13 PM
03 Altima 3.5 SE 4AT
Berk V2 w/ Apexi ~ NWP VIAS Plate ~ Racingline FSTB, Grounding Kit, Battery Tie-down, Springs ~ KYB GR2's ~ UR Ultra Sc Pulley ~ BT Under hood and Trunk Lighting
duaner is offline
post #12 of 13 Old 07-18-2010, 09:56 PM
They probably got an aftermarket cheapo motor from napa.
VQ35Alti is offline
post #13 of 13 Old 07-19-2010, 12:26 AM
silverbullet02sl's Avatar
My window does the same thing. I have taken the plastic interior panel off a couple of times and there is nothing visible behind it like what is in the diagram above. Do you have to take off the black metal panel also to get to a reset switch? I think i tried that before but then the window started falling so i just put it all back.
2002 Altima 2.5SL Traded 8/4/10
2010 Toyota Highlander Traded 3/16/11
2003 4Runner Limited V6
silverbullet02sl is offline
