No heat at idle - Nissan Forums : Nissan Forum
post #1 of 4 Old 01-30-2009, 03:50 AM Thread Starter
AltimasPrime02's Avatar
No heat at idle
Im usually good at this, and can trouble shoot pretty well, but here in rhode island its been pretty cold and want a quick solution before I trouble shoot and overspend.
I have the 2.5 (probably wont make a difference) but at idle I have no heat, car's warm, heats on, just none pumping, at take off and cruising I get heat, so Im thinking im only getting engine heat blowing through.
someone told me change thermostat but that would a cooling issue, or could it be? another thing Im thinking I have is a hickup in the system, maybe old or to not a good radiator fluid mix.
any suggestions?
2002 Altima 2.5 Sheer Silver (KY1)
Stillen front, Eracings Speedz GT Side skirts, Billet Upper and lower Grille, Tein Lowering springs 1.8 front 1.5 rear, Debadged Alpine IVA-D310 12' Kicker {15% Tint all around} 8k HIDs
Pending- 6k HID Fog's, RIMS, CAI, Exhaust, Slotted Rotors, Leather Interior, Much MUCH more
AltimasPrime02 is offline
post #2 of 4 Old 01-30-2009, 04:13 AM
It's me!!
teko03's Avatar
Quoted: 1 Post(s)
teko03 is offline
post #3 of 4 Old 01-30-2009, 06:15 AM
2010 2.5s Sedan
jimnolimit's Avatar
its blowing cold at idle and you get heat when you rev it .
99% , your coolant level is low .
1. turn the car on (from cold)
2. turn on heat
3. open hood
4. take off radiator cap
5. add coolant , try not to spill it (if you want , use a funnel)
6. let the car start to come up to temp
7. as the thermostat opens and more coolant gets sucked in , add more coolant , you might have to do this more than once .
8. put radiator cap back on .
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
jimnolimit is offline
post #4 of 4 Old 01-30-2009, 04:07 PM
silverbullet02sl's Avatar
You have air in your coolant system. I just brought mine to a shop and they drained it and put a sealant through it and refilled it and it has been fine ever since. I was constantly refilling my coolant overflow tank to max level once a month becuase it was disappearing but I think its just becuase I couldnt catch up to the amount of air that was in the system.
2002 Altima 2.5SL Traded 8/4/10
2010 Toyota Highlander Traded 3/16/11
2003 4Runner Limited V6
silverbullet02sl is offline
