Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5)
  #16 (permalink)
Old 02-26-2009, 02:48 AM
bt2580's Avatar
'Harmony'
Originally Posted by bob1234 View Post
I would like to install white color LED lights inside, but I have a concern. When the doors close, I notice the stock bulbs dim. Since LEd lights don't dim, will this cause a problem?
This is a very good question. The dome circuits on all of the Gen3 cars get brighter and dim. The duration for both is app 3 seconds. On a standard incandescent bulb, this will create a brightening and dimming effect. With a LED bulb, the effect is a little different. A LED bulb will operate on voltage as low as 6-7 volts, when a standard bulb will not. In most instances that I have seen, the LED bulb may flicker a little as the voltage is increased or decreased, and while it is 'technically' not good for the leds, I have yet to see an adverse reaction. TBH, standard bulbs do not like it much either...When is the most common time for a bulb to blow??? Either turning on or off.
Originally Posted by tuffguy515 View Post
How do I replace the light on the ignition key? ...sorry if this has been answered before but i thought it be a great question to add to the thread...does it just pop open?
Pretty good description done by nissan2003 in post #6. I will have the link up shortly for the bulb I used in my car, but it is a #37 or #74 bulb. That applies to the 02-04 models. Edit...photos added, posts 19 &20. Nice job.
Originally Posted by fourtwenty View Post
i did a small search and couldnt find anything about replacing the lights under the shift knob. the orange lights is so dim you cant even tell there is a light on.
i have blue LED bulbs from vleds so this would finish the look =]
I can only speak for the automatic shifter for certain, but the bulb in that one is a #74. In the automatic, the diffuser that contains the lettering..P,N,D,3,2,1, has an orange film on the back of it that gives it it's color. The bulb itself is just a plain old bulb. Pics below show mine. I cut a new diffuser out of opaque, white plastic and used vinyl lettering. The color of any bulb will shine through this well. I have been asked about the plastic I used, and it came from one of those pieces that you find inside a 3-ring binder that helps protect the sheets of paper...
The way it used to be, in blue...
Currently, in white...
2004 Altima 2.5 SL
Lighting Sponsored By,
Suspension Sponsored By,
Mod List(won't fit)
CarDomain Page Last updated: 10-26-2009
My Feedback Thread...
  #17 (permalink)
Old 02-26-2009, 04:39 AM
1blualti's Avatar
yea im also interested i a write up on how to change the shifter's lighting color
***For Sale** 02-04 2.5l MAF sensor, PM for Info
SE-R F&R Bumpers w/ OEM Fogs n Nismo Exhaust|XS Header|OEM Side Sills|SE-R Replica Spoiler|Rear Window m3 Lip Spoiler|Eyelids|Xenon 8000K H1 & 3000K H11 HIDs|SE-R Tails|18" TSW Thruxtons|Berk V2 Intake|SE-R Rear Sway Bar|Racingline FSTB|AutoDim Mirror|Pioneer Avic D3|Rainbow SLC 265.25 Components|Arc Audio 6x9s
  #18 (permalink)
Old 02-26-2009, 06:09 AM
nissan_2003's Avatar
Alti_junkie
Originally Posted by mazda6 View Post
great write up, maybe needs picture for some people
should be stickied
Alright its 10 in the night im bored I will do the write up right now and post it here k it will be here in like a hour I want to make it really easy and understandable <---- is this even a word hahahaha.
My car stock to the Xtreme but will get modified eventually
My new babes 1995 Eclipse GS-Turbo updated to 16g turbo still has sidemount intercooler . Just found out this eclipse was converted to AWD,
  #19 (permalink)
Old 02-26-2009, 06:56 AM
Alti_junkie
How to: Remove ignition key ring light Pt1
I am not responsible if anything happens to you if you get shocked with 50,000 volts haha jk but seriously disconnect the negative battery terminal.
STEP 1.
Pry the little plastic ring as shown below its really easy. If you cant do this then your just a plain dumba** haha.
Step 2
Remove the fuse lid located on driver side just pull it towards you. This shows one of the two screws.
Step 3
Remove both of these screws located on the left and right as shown.
Left
Right
Step 4
Pull on the HVCA control panel just a little bit till it becomes somewhat loose.
Step 5
Pull the underpanel it will just come off really easy.
  #20 (permalink)
Old 02-26-2009, 06:58 AM
Alti_junkie
How to: Remove ignition key ring light Pt2
Step 6
Now this step you don't have to remove the dimmer switch but it helps and you don't have a chance on accidentally stepping on it and ripping the cables I learned my lesson. Just remove it k.
Step 7
Now you car should look like this. Grab the clear ring and it pull it towards you it will slide off. Don't yank it hard just give it a little wiggle it WILL come off.
Step 8
Pull the clear ring towards you after you take it off slowly. Its kinda hard but just keep pulling exposing more wire to work with. Then just turn bulb counter clockwise and VOILA there it is the bulb just take it out and slap on the L.E.D.
To install everything just do above in reverse order k
Copyright of Nissan_2003 haha
  #21 (permalink)
Old 02-26-2009, 07:00 AM
Alti_junkie
^^This is for 02 03 and 04 altimas. Maybe its the same for the 05 06 probably same step just different panel looks or something dont know haha.
  #22 (permalink)
Old 02-26-2009, 07:08 AM
bt2580's Avatar
'Harmony'
Both answered in Post #16...
  #23 (permalink)
Old 02-26-2009, 07:31 AM
tuffguy515's Avatar
excellent write up!! and super easy !! very clear!! 2 thumbs up!!
im waitin on my led to arrive for the ignition ring, and then ill follow those steps ...thanks mang
mines 05, so we'll see if its the same..should be tho
http://www.youtube.com/user/tuffguy515
...it beats walkin
  #24 (permalink)
Old 03-10-2009, 12:30 AM
VisualAuraVA's Avatar
BLKPHNTM
I followed all the steps for to change the key ring. but my leds stay on all the time know. Does anybody know why this is.
Is it bad for the battery to be running this led at all times.
Lincoln, Ne
  #25 (permalink)
Old 03-10-2009, 12:37 AM
Alti_junkie
Thats weird and I mean it wont drain your battery since that led dont use alot of energy but it not normal for it stay on maybe one of you doors is not closed properly or something. They key ring is suppose to turn off on its own. When you take the key out it turns on. Did it always do this or no before you put the new led. Is the led on when the car is on as well or no. You are the first with this problem I think. Talk to vleds or pm bt2580 they should know something if you bought the led from them.
  #26 (permalink)
Old 03-10-2009, 12:42 AM
porschebk85's Avatar
2nd Gen Boy
Hey bt2580, you wouldn't make a led suggestion guide for 2nd Gen Altima too would you?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
2001 Altima GXE - [8K HIDs] [De-badged] [ UR Pulley ] [injen intake] [OEM Spoiler] [OBX TB Spacer] [40% Tint] [ Stillen Rotors & Hawk HPS Pads] [TYC Tails] [ license]
<Car Domain> <♪My Pandora♪> Proud fiancés of an EMT-I/Firefighter
  #27 (permalink)
Old 03-10-2009, 12:54 AM
kasey07's Avatar
shift_wheel hop
props on this thread now led noobs like myself can just point click and buy.
  #28 (permalink)
Old 03-10-2009, 01:06 AM
BLKPHNTM
Thanks for the quick reply. I have this black ring with wires in it around my ignition ring. I think that might have something to do with it becuase of its close proximity to the ring. I really have no idea.
The light has never acted this way before. Normaly when the car was on, it was off. And then when turning off the car it would stay on for a minute or two.
Any advice that anyone has would be great. I just don't want my battery to die.
  #29 (permalink)
Old 03-10-2009, 10:35 AM
Alti_junkie
hHHHmmmm maybe some those wires are messing with the key ring lights. Since you moved them maybe the wires are touching or something like that. Check your wires tho. I have never herd anything like this from members on here,
  #30 (permalink)
Old 03-10-2009, 01:47 PM
Goon
is there a way to change the color of the light like where ur speedometer and all that stuff is? Because I just got a new head unit which has blue lights around its dials and everything and the orange and the blue look kind of tacky.
