Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5)
  #46 (permalink)
Old 03-25-2009, 08:52 AM
bt2580's Avatar
'Harmony'
Originally Posted by theonedub View Post
any update on that new 3157?
Nothing yet...As I stated, it was a prototype bulb. They are trying to get another one in by the end of the week, and the set will go in my Alti for testing.
2004 Altima 2.5 SL
Lighting Sponsored By,
Suspension Sponsored By,
Mod List(won't fit)
CarDomain Page Last updated: 10-26-2009
My Feedback Thread...
  #47 (permalink)
Old 03-25-2009, 10:19 PM
Thank you for your response, now I won't drive myself crazy trying to get the map light to work! As for the license plate, I just found it too bright in one spot but with the stock bulbs, it's kinda spread arcoss the whole plate area. I still like the white light though.
  #48 (permalink)
Old 03-25-2009, 11:16 PM
Zyphron's Avatar
Ah. I do <3 Ale.
Originally Posted by bt2580 View Post
***NEW STOP TAIL LIGHT COMING SOON***
I was at V-LEDS this evening and got to play with a new 3157 prototype bulb. The parking circuit is a bit brighter than my current bulbs, but the brake light circuit is easily 3 TIMES brighter. Unfortunately, they were only shipped ONE bulb so far, otherwise I would have stolen 2 of them.
Ok, i JUST noticed this
3156 and 3157 are Identical IIRC right? the later is just missing the extra leads and filament
I explained it In a Eariler post. but... you think its possible to run one circuit for the running lights. and another for the turns
most of it would stay the same you just have 2 more wires going from the turns and tapping onto the running lights power
some cars Incorprate Brake, Running and Turns into a single Housing (mustang comes to mind)
Kind of a similar Idea to the switchbacks you used as reverse/turn lights (brilliant btw)
  #49 (permalink)
Old 03-26-2009, 02:59 AM
bt2580's Avatar
'Harmony'
I answered this in another thread awhile back...Matter of fact it was the one about doing the dual reverse lights...
The answer is yes, it will work fine. Hook the low element(dimmer) lead to the parking circuit, and the high element lead for the turn signal. I was considering doing this when I was looking at SER tails...Before I came up with the current setup that I am using. In other words, the idea was always there, just implemented in a more unique way with the clear housings.
You will need to get a couple of 3157 sockets for the Altima. I had to trim one of the alignment tabs to make it all work...Actually, if you would like, I can sell you a pair of them that I have, and I can trim them for you...
For those of you who are unaware of what Zyphron is refering to about my tail lights...I have 4 reverse lights.
I replaced the 3156 turn signal socket in the aftermarket housings with a dual conductor, 3157 socket, and installed dual color (amber/white) LED bulbs.
  #50 (permalink)
Old 03-26-2009, 02:04 PM
bt2580's Avatar
'Harmony'
Glove Box Light
Originally Posted by EBAN44
Hey
Hope I'm not like the billionth person to Message ya about a question just didnt want to start a new thread.
Question:
I bought the glove box LED and various others but when I got to the glove box my light was already out its a 06 so thought it was weird that it was dead already since I rarely open it. Well I installed the LED bulb (tried both ways) and then tested it in the trunk and it turned on but still no light in the glove box. My dome light and all other lights work so guessing not a fuse.
Any Ideas???
THANKS
Also your 15% off code still works and love my LED upgrade thanks for the deals and forum help
This was moved here from a PM I got...
Anyways, the glove box light in the Gen3 cars is tied into the parking light circuit...It does not come on unless your other lights are on.
  #51 (permalink)
Old 03-31-2009, 03:32 PM
Is it possible to change the keyring light to white LED? I checked and 05 is different than 03 pics posted here. Can't seem to access the light without taking the whole front dash apart.
Thanks.
  #52 (permalink)
Old 03-31-2009, 04:35 PM
bt2580's Avatar
'Harmony'
Thanks.
I have not personally done the swap in an 05, but it can be done. I took a look at the 05 service manual and it shows the 2 screws that hold that lower cover in place to be simialr to the 02-04...
Anyone with an 05/06 want to chime in on this one???
  #53 (permalink)
Old 03-31-2009, 04:55 PM
Looks like pre 05 the key ring is part of the bottom panel according to pictures posted earlier in page 2. But it's not the case anymore with 05, the keyring portion is part of the upper dash.
I took out the lower panel anyway but no way I can access it, there's no room at all.
Unless there's a way to pop that ring out easily? Thanks.
  #54 (permalink)
Old 03-31-2009, 04:58 PM
bt2580's Avatar
'Harmony'
This has been asked before...I'll stop by and see if I can rip apart my buddy's SER today and take some pics...
  #55 (permalink)
Old 04-01-2009, 03:22 AM
bt2580's Avatar
'Harmony'
05/06 Key Ring Light Swap
OK, so I finally have swapped a key ring bulb in the 05/06 model. Pics shown below are of my friend's 06 SER...
I first tried to remove the lower dash panel, but had no luck getting to it that way.
Next I removed the steering wheel shroud...Still could not get to it.
Finally, I removed the gauge cover and took the screws out of the gauge bezels as well to allow them to be rotated out of the way(I did not disconnect the wires to the gauges...) This finally allowed me to get to the little bugger and get it swapped.
Here are the pics...
LOWER PANEL REMOVAL(not necessary to do, but would not hurt)
-Remove phillips screw under fuse cover
-Remove phillips screw on right, bottom side of panel
-Pop loose the bezel around the HVAC controls(pull from bottom)
-Pull lower cover loose...
STEERING WHEEL SHROUD
-Remove (3) phillips screws from bottom of shroud(easier with wheel tilted all the way up)
-No pic, but pull the two halves of the shroud apart...There are little snap in tabs on it.
GAUGE COVER AND GAUGES
-No pic, but just pull up on the cover above the gauges
-4 screws hold in the gauge cluster, 2 on top, 2 on the bottom, all phillips head
-Top 2
-Lift rubber flap to find the 2 on bottom...
Left...
Right...
-How I had screwdriver to remove bottom screws...Steering wheel is tilted all the way down.
-Rotate gauge cluster 90 degrees to left(may want to put a towel on dash)
CHANGE THE BULB
-Simply(yeah right) rotate the plug and remove...
-Change out bulb(check to make sure it is working, or flip bulb around)
WHITE!!!!!!
Reassemble car.
  #56 (permalink)
Old 04-01-2009, 03:34 AM
Thank you so much for posting the pics, very helpful. I was going to ask how to remove that steering wheel shroud as it's making some noise when going over bumpy road, this is going to be great.
I bought these from V-LED's:
2 V-LEDS 3 SMT HID WHITE WEDGE BASE DASH LIGHT BULBS 37 74
I hope they're the one for the ring?
Thanks again, I'll work on it probably in the next day or two, will post back if I can get everything piece back together
Just to make sure, the gauge cover I just have to pull up straight? Should I be worried if I use too much force to break anything
Thanks again for all your help. White LED is so much nicer.
  #57 (permalink)
Old 04-01-2009, 03:36 AM
And there's nothing to disconnect aside from moving the clusters around to better access the bulb?
  #58 (permalink)
Old 04-01-2009, 03:47 AM
Is it possible to do this with the front park/turning lights; parking lights white, turn signals amber?
  #59 (permalink)
Old 04-01-2009, 03:53 AM
bt2580's Avatar
'Harmony'
That bulb will work great.
As to the gauge cluster, just get it loose and rotate it up out of your way. No need to disconnect any wires from it.
  #60 (permalink)
Old 04-01-2009, 04:00 AM
bt2580's Avatar
'Harmony'
Yes, I already have those bulbs in my car as well. This will only work with the 05/06 Altimas that have the clear turn signal lenses, or in my case, aftermarket housings that had them for the 02-04...
This is the bulb to use, and you will need turn signal resistors
V-LEDS TYPE 2 DUAL COLOR CHANGING WHITE/AMBER 60 M-SMT TURN SIGNAL BULBS 1157 2057
And a pic of the white parking lights...
