Fuel Filter - Nissan Forums : Nissan Forum
post #1 of 17 Old 03-19-2009, 12:18 PM Thread Starter
Fuel Filter
Hi Guys,
Any one of you have replaced fuel filter on 2003 V6 Altima? I want to replace it due to my mileage on it about 105,000K, have problem keep idling on first start up and kill and start it again, idle fine after that. I replaced all spark plugs and still does it so i am looking to replace fuel filter next but can't find it. Please help me or lead me to the right symptom. Thanks.
2003 Altima (AT) 3.5 SE
JohnyKing is offline
post #2 of 17 Old 03-19-2009, 02:05 PM
It's the llama talking
Penguinchit's Avatar
Quoted: 119 Post(s)
I was told the access was under your rear seat. There are 2 pull tabs under each end of the front of the rear seat. Tug those and the seat will come out. Then unscrew the black panel underneat and that should be your pump...
05 3.5SE AT
Lightly modded
Penguinchit is offline
post #3 of 17 Old 03-19-2009, 03:35 PM
slvrbackgorilla's Avatar
Quoted: 13 Post(s)
is that for the filter or the pump? he is looking for the filter.. to the O.P, maybe you can google it. you'll be surprised how much info you can get on that website..lol. good luck!
slvrbackgorilla is offline
post #4 of 17 Old 03-19-2009, 03:58 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
Google Answer:
The fuel filter in a 2002 Nissan Altima is located in the fuel tank and is a non-serviceable item. That is what the dealer told me. You can always call up the dealer and ask them where something is located, after all you paid thousands of dollars and bought a warrenty so don't be shy about calling them up and asking them questions. However dealers can be expensive, so shop around for the best price or find a friend who can help and save yourself a bunch of money.
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is online now
post #5 of 17 Old 03-19-2009, 04:10 PM
Quoted: 119 Post(s)
Good call...Yup...Me...Half-paying-attention as usual...
It's surprising I've made it this far in life!
05 3.5SE AT
Lightly modded
post #6 of 17 Old 03-19-2009, 04:24 PM
Quoted: 13 Post(s)
LOL!!!! it happens to the best of us!!
post #7 of 17 Old 03-26-2009, 10:39 PM
DNA
Try a bottle of Gumout Regane or some SeaFoam and see if that doesn't help. I use a bottle of Regane right before any oil change and i've not had any problems. Make sure to pick up the clear bottle. As for me. I've got a 05' 2.5S w/ a little over 100K miles.
Dan
p.s. the bottle should look like this http://ecx.images-amazon.com/images/...500_AA230_.gif
"Take your hand off the gun... and stop smiling."
DNA is offline
post #8 of 17 Old 03-26-2009, 11:07 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
Dan
Looking for something?
We're sorry. The Web address you entered is not a functioning page on our site
Go to Amazon.com's Home Page
*Bumper Plugs
Garage:
*12 Quest SL
post #9 of 17 Old 03-26-2009, 11:59 PM
The VripMaster
after checking in Alldata, the fuel filter is a non-servicable parts.
CDXX is offline
post #10 of 17 Old 03-27-2009, 04:51 PM
DNA
Is what you should be looking for. And yes, the fuel filter is in the tank.
Dan
p.s. Your air filter has been changed every 12-15k miles right?
DNA is offline
post #11 of 17 Old 03-27-2009, 08:28 PM
shift_wheel hop
kasey07's Avatar
to change the fuel filter you have to change the pump it is inside the pump
kasey07 is offline
post #12 of 17 Old 03-28-2009, 05:59 PM
Majestic '06 3.5SE, 5 spd
froedrick's Avatar
Quoted: 1 Post(s)
Gotta be careful with the Seafoam. A few of the guys have had some real problems after using it.
Traded 10/10/11 for a 2012 Hyundai Genesis Track Coupe.
froedrick is offline
post #13 of 17 Old 03-28-2009, 07:31 PM
ScottieBoy's Avatar
Quoted: 3 Post(s)
Not sure if this is the problem, but I know on both my suburban and my brothers Tahoe, we both had that same problem. It would kill immediately after startup then run fine after the second start. Or sometimes you would have to crank it for a long time before it would start, but run fine after it was started. It turned out to be the fuel pressure regulator on both trucks. So I'm guessing its a possibility thats your problem. Its worth a shot to check into it. Just my 2cents.
ScottieBoy is offline
post #14 of 17 Old 03-29-2009, 06:43 AM
Could be moisture in the fuel line. put some "dry gas" in on your next fuel up. i dunno the actual name but the description should be something along the lines of "gets rid of moisture in your gas". its probly near the fuel injector cleaner section of the gas station.
abrown250 is offline
post #15 of 17 Old 04-06-2009, 12:05 PM Thread Starter
Hi Guys,
I still have this problem "It would kill immediately after startup then run fine after the second start". I replaced all my spark plugs, put one bottle of heet and injector clean in the full tank of gas and still does it. Is any one have replace this "fuel pressure regulator" in our alti yet and should it be at where. I need all your help guys and I search on google and found out that a lot of owners altima 2.5 had replaced this part too "crankshaft position sensor" due to the same proble I have right now, some one have suggested to check recall on it. Yes check my recall on my altima with my local dealer and is up to date, No open recall on it. I am want to replace this "Crankshaft Position Sensor" Is this the righ one for now. Thanks.
