the pic i posted above is correct , but for some reason both high and low valves are in the same place on that altima , some models are different . the valve on the large A/C line is the low side . here is a better pic , l'll add this pic above .
or this :
__________________ MY AUTO BLOG (COMPLETE WITH INSTALLS).
The hose wont fit over the other one anyway, so you cant do any harm.
I did this for the very first time on this car since i bought it, took about 5mins. Turn the car on, A/C on full blast, shake the bottle well, hook it up and the gauge will tell you right away where you're at, if you need to add, do nothing, its already beyond full (more pressure than needed), or the A/C has other mechanical issues and need to be looked at by a Pro.
Mine needed to be recharged and didn't take much and the A/C is blowing cold air like before.
you have to have the car on and the a/c down to the lowest temp (60º for me on the digital unit) and you have to have the fan on all the way... other than that you just hook it up until it stops pretty much
So when the bottle says it will increase the gas mileage, are they full of shit or will I notice a little difference? I've been getting shitty mileage for a while now, and I've been trying to figure out why. Would the air conditioner not being charged be a possible reason?
So I dont add if I do need more? I dont get this part.
wolfpacrules :
I am doing oil change and when I pulled out the oil filter, only about 1/3 Qt of oil came out.
Sentinal: Ummm....are you trying to do an oil change through the filter???
^^^^ What he said.
Once you hook up the hose and the car is running and the A/C is running at full blast, the gauge is color coded and tells you where your A/C stands.
I believe pur cars should be between 45-55 on the pressure gauge. I left mine at 50 after recharging but it still throws hot air. I know I have to change the cabin air filter, would this be a cause for the hot air?
__________________ 2002 | 3.5
Stillen FTB | NWP VIAS Plate | Idle Time Advanced +2 |NGK Plugs |
Maxima Berk WAI w/ Apexi | Brembo Rotors | Akebono Pads | 35% Tints |
Eibach Pro Kit | KYB GR2 | Energy Suspension Bushings | RL Rear End Links|
AT S2 Grill | AT Lower Grill | CF Tails | Custom Altima Step Plates |
BT Aux Input | BT Trunk LEDs | 8000K Headlights | 6000K Fogs |V- LEDs |
Optima RedTop | Falken Ziex 912s on stock | 18s RH Evos w/ Pirelli P60s | Magnaflow High Flow Catalytic Coverter|
About to install:
NWP 5 pc Thermal Kit | Racingline Grounding Kit |
2004 | 2.5: Brembo Rotors | Akebono Pads | Kuhmo on stocks| 1997 Altima: Sold
I dont think the incabin air filter could cause the air to come out hot, it might come out slow because its clogged but it would still be cold if everything else is the same.
You might have a leak. The dealer told me that my A/C had a leak back in early winter and that it would cost $400+ to fix it, and when i asked 400bucks, he said oh we have to recharge it. Recharge it?, I bought the BiG Ass can for 26bucks plus taxes and probably used 40% of it if not less and the car is blowing cold air like always, bunch of thieves.
Now, I dont know if what he said was true, but seems to me that a bunch of us have done the a/c charge thing, and many with altimas much younger than mine, since mine is almost 8 years old and this was the first time i had to do it, maybe its just time!
Ill try to change the filter over the weekend. As far as a leak, I bought 1 can of regular recharge and 1 small can of recharge with leak fix even though I dont think I have a leak.
Our cars are twins, same V6s, color and age...
I really dont know what to tell you, mine was blowing warm air and then started blowing cold air as soon as i recharged it, it was like back from the dead, It might be something else like the bullshit service that the dealer always tells me they can perform this time of the year, they clean the system using some sort of spray, changed the filter and something else, you might need that
I know we have the same car, I was just making a general statement that many of us needed to recharge the A/C as its not unsual to do so even with newer model altimas, even though somebody said and i dont know how true his statement was, that you really dont need to recharge the A/C unless something is wrong because the R-34 or whatever is supposed to stay there all the time!?
the cabin filter will NOT cause the A/C to blow hot .
if you have the proper amount of freon in the system and the A/C is not working , the pressure switch is probably bad .
the Dryer/receiver is attached to the condenser coil therfore any major work requiring more then 2 hours of open air exposure will require that to be replaced. not fun.....
Any of the "stop leak" shit you can Fill your car with is usually bullshit and is just a marketing ploy to get you to by that can over the other stuff
Like said above me. R134a should never require refilling.
from the factory the Altima's AC is charged with UV reactive (neon green) compressor oil, it makes finding leaks pretty easy with a black light. unless you have a massive leak and the oil gets over everything. which then you should be able to find the hole in the hose
sure you may only need a recharge every year or 2 but if your not replacing your 8YEAR OLD HOSES your going to have leaks/failures
when the system leaks it does not just leak Coolant, it leaks oil too, more so then coolant.
and if you keep the AC system running without oil your compressor will eventually seize up on you, toss the belt and may do more damage then if you just had the service work done earlier. that Oil also Condtions the O-rings in the system, which a cracked/broken O-ring is bad news.
rubber hoses Go bad, (rot) the Discharge and suction lines off the compressor both have Rubber hoses in them that should be replaced every so often.
the hoses are cheap and if you buy them yourself Nissan will do the install for you and not charge you for the part (saved me about $120)
and unless you Have the tools there is really no way to get around taking it to a shop.
you need a High side and low side hookup, A Vacuum to test for leaks and to remove O2 from the system. then you need to know how much Oil the system takes ect.... too much refrigerant is worse then not enough.
also 400 is way over the top for a drain and fill. they just hook their system up, suck out the old oil and Coolant and replace it with new stuff.
they quoted me like $112 for just the Drain and refill which covers the disposal of the oil and refrigerant. (its illegal to vent refrigerant)
