Shift lock solenoid control unit - Nissan Forums : Nissan Forum
post #1 of 9 Old 06-07-2009, 07:02 PM Thread Starter
Baba-T
lilteelaw22's Avatar
Before going to church today I got in my car turned it on and tried to shift (automatic) from park into reverse but the shifter refused to move. I then noticed that I longer heard the click sound I would usually hear when I pressed on the brake to shift the car from gear to gear. Im quite certain its the Shift Lock Solenoid. Has anyone had this problem. Also how do you replace it?
thanks for any input....
lilteelaw22 is offline
post #2 of 9 Old 06-07-2009, 08:14 PM Thread Starter
Baba-T
Nevermind got it fixed it was a blown fuse....
Thank God.......
post #3 of 9 Old 06-26-2009, 09:11 AM
my altima is doin that now and i can't get it out of park what fuse.
altimatnn is offline
post #4 of 9 Old 06-27-2009, 12:00 AM
1Lil C's Avatar
Just like, lilteelaw22's Alti, try checking your fuse.(inside ones) I belive it was was the one labeled "Electric..." Can't remember. The same thing happened to me as far as the shifter. My interior indicators would not come on as well. Good luck.
1Lil C is offline
post #5 of 9 Old 06-29-2009, 05:42 AM
shifter stuck
I just wanted to add a link to my post. I have a similar problem but I do not believe it is the fuse. I have posted a link to a PDF in my post that has many pictures detailing how I took apart the center console, the buttons that detect that you have pressed the brake and the little motor and button at the shifter that block you from shifting. Hope this helps someone like me that haven't taken anything like this apart before or has a hard time visualizing what is going on with this problem.
I believe the cause of mine is either the button at the pedal or the little motor at the shifter. I should find out tomorrow.
http://www.nissanclub.com/forums/200...ml#post3788446
End the end my solution was to use a zip tie to keep the switch by the shifter depressed. The Nissan store only sells the entire shifter unit the little motor thing that depresses the switch does not come off as a separate part. That entire assembly is about 400 bucks. So the car will shift without my foot on the break but I have 400 more in my pocket.
rhdowns is offline
post #6 of 9 Old 10-02-2009, 06:41 PM
Shift_me
Just to add on- I was messing out with interior lights yesterday and in the process my screw driver touched the bulb contacts, shorted, and blew a fuse. My shifter would not come out of park. First check eletronic fuse, if not then check all others too. Most likely a fuse that controls the unit which tells you put your foot on the brake.
yar786 is offline
post #7 of 9 Old 10-02-2009, 07:40 PM
FERRARI SLAYER
Genocide's Avatar
i did the same thing with the screwdriver on my vanity lights...blew a fuse replaced it n they still dont work alon with my interior indicator...and the shift lock is stuck..i jus live with it though its ot a big deal....i rigged up a little piece to put in the shift lock hole n now it works fine
Gold 02' Altima 2.5
PERFORMANCE MODS. WHO CARES ABOUT THE REST RIGHT?:
Tsudo Catback
2J Racing Underdriven PS pulley
Lightweight crank pulley
Cut balance shaft chain
Custom SRI
2J Racing Intake Manifold
Stillen Header
Stillen Catless Midpipe
TB Bypass
Indexed NGK Iridiums
Genocide is offline
post #8 of 9 Old 10-02-2009, 11:33 PM
I've always thought that that weird solenoid "click" when you step on and let off the brake pedal when stopped (or almost stopped) was one of the oddest things about the Altima.
Never had another car do that, very strange. But I guess its better than not being able to put it in Drive!
trooplewis is offline
post #9 of 9 Old 10-03-2009, 12:27 AM
Shift_me
Hey guys I have a solution for you. I went out to my car and found the fuse responsible for the shifter solenoid. The same fuse can also cut off power to the map light, dome light, the beeping sound when you leave the keys in the ignition and the doors are open.
Fuse is called "Battery saver" was blown on my car. This is located inside of the car to the left of the steering wheel near hood latch. Sorry about the dark picture but its all I have at the moment. Hope this helps.
To the guy stating the sound is weird, yes its weird but if you think about other older cars you had to press in a button on the shifter before you could move it. Sound doesn't bother me as much as it used to.
yar786 is offline
