Clicking noise when Turning the Steering wheel - Nissan Forums : Nissan Forum
post #1 of 21 Old 06-18-2009, 05:36 PM Thread Starter
Roamer of the World
toocoo's Avatar
Exclamation Clicking noise when Turning the Steering wheel
Hello all,
I am new to this board.
I just aquired a 2003 2.5S with 114K miles. It has a few problems most of which i've found answers for, except for this weird clicking noise that I hear when I turn the steering wheel. At first I thought I could have been the CV joints but it happens even when im at a dead stop and I turn the wheel. Which leads me to believe there is something wrong with the steering or power steering. Even when the engine is off it still makes the noise.
Any help is appreciated. This forum is great for nissan owners. I look foward to interacting with ya'll.
toocoo is offline
post #2 of 21 Old 06-18-2009, 11:35 PM
2010 2.5s Sedan
jimnolimit's Avatar
if its not the CV joint , it could be the joint in the steering column that leads to the steering rack .
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
jimnolimit is offline
post #3 of 21 Old 06-19-2009, 12:22 AM
Code Red
SE-R Tuner's Avatar
Could be something in the steering column but I wouldnt think so. Check your lug nuts for your wheels to make sure they are not loose, other then that I would have to see, feel, or hear it...
^Not your average 4-door^
No tune 5 A/T
60' 2.03
13.91 @102.37
SE-R Tuner is offline
post #4 of 21 Old 06-19-2009, 12:28 AM Thread Starter
Roamer of the World
toocoo's Avatar
well I say that its not the CV joints but i had an acura in the past that had a bad CV joint and its a totally different sound. Im gonna go see if i can take a small video of the noise. But im thinking like jimnolimit that it might be something connected to the steering.
toocoo is offline
post #5 of 21 Old 06-19-2009, 12:30 AM
jkgultimate's Avatar
Originally Posted by toocoo View Post
Hello all,
Your power steering will make a REALLY loud whining noise so its not that. Check all your front stabilizing links or check even for broken ones.
If you don't see the problem there, check up your front end and wiggle the tire by grabbing the tire from opposite ends.
First put your hands on top and bottom and give it a wiggle and then put your hands across the tire and give it a wiggle. If there is play up and down, you have a bad ball joint.
If you have a wiggle side to side, your tie-ends are no good. It could be either the inner or outter tie-rod end so check both parts for movement when you get under the car. I would recommend someone doing those wiggles and you check for any unusual play.
2007 Altima 3.5 SE 6MT Bone Stock! 14.180@100.16 MPH (70F)
----Dynapack: 242WHP, 217.5TQ ---Dynojet: 266WHP, 239 TQ (Fujita intake only).
1995 Eagle Talon TSi (Modded) 12.21@116.47 MPH (70F)
AS OF AUGUST: 11.2@129 MPH (85F) NEW SETUP.
1998 Lexus GS400 5At (BONE STOCK) 14.36@97.21 mph
jkgultimate is offline
post #6 of 21 Old 06-19-2009, 12:38 AM
SHIFT_excitement
aviatorwes's Avatar
Did you notice the car stray from side to side while holding the wheel straight when you were driving it? If so then its probably a bad ball joint or tie rod like stated above.
Injen CAI, Unorthodox crank pulley, VIAS delete, B&M short shifter, APR front strut bar, OBX headers, NISMO Y-pipe, Straight pipe to Magnaflow mufflers, Wilwood BBK, NGK plugs.
aviatorwes is offline
post #7 of 21 Old 06-19-2009, 01:38 AM
Code Red
SE-R Tuner's Avatar
Lol oops im stupid, forgot all about ball joints and tie rods. But if it was a ball joint you would hear more of a popping noise. Just jack the car up rotate and wiggle the tires and stuff and you should be able to see or feel whats going on. Also look for any broken boots and seals ie. if your tie rods boot is sliced or cracked chances are that would be your problem...
No tune 5 A/T
60' 2.03
13.91 @102.37
post #8 of 21 Old 06-19-2009, 01:45 AM
i have the same problem too. i hear a "click" when i turn the steering wheel half way around. i thought it was a loose screw or something holding the steering column cover but i'm going to have to look into this.
sorry for hijacking but sometimes, i would hear one of my tires wobble when i drive over uneven roads...does this have to do with the ball joint/tie rod or is it just a bad wheel bearing?
Performance: | AEM CAI | Magnaflow resonator-Stock pipes-Magnaflow 14862 muffler | XS Header
Cosmetics: | 35% tint | OEM sidesills | OEM splash guards | OEM Fogs | McCulloch 6k HIDS | Raptor 6k Fog HIDS | LEDS | BT footwell LED kit | BT underhood LED kit | SE-R tails | AT S2 grille | Debadged | Red calipers | DIY Blacked out headlights | RL BTD |
Wheels/Suspension: | 05/06 SE Alloys-Yoko Avid TRZ | RL FTSB | Stillen RSB | RL REL |
pbwillz is offline
post #9 of 21 Old 06-19-2009, 02:30 AM Thread Starter
Roamer of the World
toocoo's Avatar
I just took a quick trip down the street and im hearing a cluncking noise from my front wheel.
Im thinking that we could be having the same issue. This weekend im definately gettin the front wheel off and seeing whats the deal. Ill keep everyone posted.
toocoo is offline
post #10 of 21 Old 06-19-2009, 04:21 AM
Code Red
SE-R Tuner's Avatar
If there is clunking then it could be a ball joint and you shouldnt wait to look at it! My friends car rolled because his ball joint popped out when he was doing a lane change on the highway and my wifes popped out and almost cause some major damage. Anyway poping or clunking sounds like a ball joint to me...
As for the other guy experiencing "wobble" that sounds like a wheel bearing to me and also isnt good, wouldnt put that off either. Jack the car up and spin the wheel. If it wobbles or you can make it wobble chances are its a wheel bearing...
No tune 5 A/T
60' 2.03
13.91 @102.37
post #11 of 21 Old 06-19-2009, 04:43 AM
Ctrl-F Yourself
200hpAltima's Avatar
Quoted: 2 Post(s)
If it turns out to be none of these. Check the steering rack. Not the column or the pump but the rack. Ponticas have a major problem with their racks (tehehe play on words) and they click when you turn the wheel either way.
E-Racings Front|Tint|Tsudo Catback|Verde 18's|Woodgrain Dash Kit|Tinted Tails|Vinyl Behind Mirrors| Too Much to List!
DIY LED Tursignals In Mirrors|DIY Projector Retrofit|What You Need to Convert to OEM HID|Nissan Factory Service Manual Here|How To Check/Clear SES Codes HERE|Upgrading The Stock Halogen Headlights|Detailed Description of HID and Angel Eyes
BEST IN CLASS AT 2009 CANAL DAYS CAR SHOW!
Originally Posted by KeVQ35 View Post
Your car is like the ugly chick that all the guys look at in disbelief, but she tells all her girlfriends that guys are constantly checking her out.
200hpAltima is offline
post #12 of 21 Old 06-19-2009, 12:49 PM Thread Starter
Roamer of the World
toocoo's Avatar
Thanks everyone for thier insight...I have a .2 mile commute to work so im not too concerned with it popping out on me. But tomorrow im taking it to my lil tool shed at my dads fab shop and gettin that wheel off and taking a good look at whats going on...ill be sure to take pictures and post up what the problem was.
toocoo is offline
post #13 of 21 Old 06-19-2009, 09:02 PM
SHIFT_excitement
aviatorwes's Avatar
This sounds like it could be a bad CV joint. If it clicks when you turn then thats probably what that is.
post #14 of 21 Old 06-21-2009, 04:29 AM Thread Starter
Roamer of the World
toocoo's Avatar
Well had a father in law take a look at it (hes a mechanic). and my struts and shocks are shot!. and my 2 front motor mounts are crapped out. He said my CV joints and boots are fine and he doesn't see any problems with them. So as i fix those problems ill update and let yall know if it took care of the clicking noise.
toocoo is offline
post #15 of 21 Old 06-21-2009, 09:39 AM
2010 2.5s Sedan
jimnolimit's Avatar
if he said your struts are shot and it makes a clicking noise when you turn , it sounds like your top strut mounts are bad .
