Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5)
Old 07-03-2009, 11:12 PM
The first bt2580 footwell led kit (pics)
So, bt2580 made me "the first footwell led kit" upon my request. This kit is basically plug and play. Everything is wired, trimmed, connected, so on and so forth. It is manually operated with a switch. The kit uses two 6" white led strips. The kit came with instructions and it was very easy to follow. The only problem I came across was that I didn't have a 1/2" drill bit to drill the hole on the blank cover switch. Eventually, I used a smaller drill bit to make the desired 1/2" hole. Just in case if you're wondering what I'm talking about, you need to drill a 1/2" hole on the blank cover switch so that the actual switch can be held in place.
bt2580 is building a few kits that will come on with the dome/keyfob/door and this is the kit he is offering for sale. If you are interested you can PM him.
Pricing for the kit can be found on page 16, post #254. Here is the link : http://www.nissanclub.com/forums/200...ml#post3804490
Enjoy the pictures. Note: The pictures of the LEDS are dim but they are brighter in person. There is also a video in post #2.
Everything in the kit...
The switch...
This is where the strip was mounted on the driver side...
This is where the strip was mounted on the passenger side...
LIGHTS ON
Performance: | AEM CAI | Magnaflow 18x6 resonator - Stock pipes - Magnaflow 14862 muffler | XS Header
Cosmetics: | 35% tint | OEM sidesills | OEM splash guards | OEM Fogs | McCulloch 6k HIDS | Raptor 6k Fog HIDS | Interior LEDS | bt2580 footwell LED kit | SE-R tails | AT S2 grille | Debadged | Red calipers | DIY Blacked out headlights | RL BTD |
Wheels/Suspension: | 05/06 SE Alloys | Yoko Avid TRZ | RL FTSB | Stillen RSB | RL REL |
Old 07-03-2009, 11:14 PM
Old 07-03-2009, 11:22 PM
spike228's Avatar
Mark of Shame
Nice. I wonder how he's going to implement the one that comes on with the dome light. Tapping the BCM wires isn't exactly something I would trust a whole lot of people to do without messing it up.
Cardomain
Mods:
| Apexi V2 | Hella Optilux 1180 / Apexcone 3000k | Polk DB6500 + Polk DB690 | Apexcone 5000k | Racingline FSTB | Nismo Catback | AT S5 | Nismo 57F / Potenza RE01R; 245 45 18 | Redline Quicklift Elite | Hotshot header | Jihad folding mirrors | Nismo RSB | Audi DRL | Tein SS w/ EDFC | Racingline MMI | 350z seats | JWT BSR | Wilwood 4pot superlite w/ 13" 2 piece | F+R RL endlinks |
Testing: RedLionRacing Traction Rod Prototype
Old 07-03-2009, 11:57 PM
200hpAltima's Avatar
No More Nissans....
The dome light kit is for me. Bt2580 is in the process right now and i hope to have this kit in within two weeks or so. I do believe the dome light one is tapped into a fuse that the dome light works its way thru but im not sure. I am also getting mine in white and am gonna love it!
Will can you post a pic of the drivers side footwell LED placement since i will not be taking off that dash piece? Thanks in advance man!
200hp
03 2.5 SL. Loaded|Debadged|Trenz grille|Eyelids|Stillen front lip|38/20 tint|Catback, Magnaflow muffler|LED dome/map/puddle lights|Vinyl Behind Mirrors|DDM 6000 & 3000K 35w HID's|Redline QuickLift's|Wood Grain Dash Kit|LED Turns In Mirror|LED Footwell Kit
BEST IN CLASS AT 2009 CANAL DAYS CAR SHOW!
Old 07-04-2009, 12:00 AM
bt2580's Avatar
'Harmony'
200hp
It is basically centered on the panel underneath and the wire routes through where the OBDII connector is.
2004 Altima 2.5 SL
Lighting Sponsored By,
Suspension Sponsored By,
Other Pics
CarDomain Page
My Feedback Thread...
Old 07-04-2009, 12:05 AM
bt2580's Avatar
'Harmony'
I am researching the 05-06 models, but from what I can see, Nissan used the same wiring color code for the dome circuit from 02-06. Simple ScotchLock's will be used there for tapping.
The other issue I have run into is that while all of the 2.5's have the blank switch cover near the dimmer controls, a good portion of the 3.5's have the TCS located there. I am looking for a clean place to install the switch on those vehicles.
No More Nissans....
Gotchaa and if your wondering why im not taking the dash off, its because im not putting that switch there. Im gonna hide it up under the dash and run it almost full time with the domes lol.
Clearing things up bt: it will have a constant off, constant on, and dome light function on the switch correct?! lol Sorry haha
Old 07-04-2009, 12:08 AM
m_turner_02's Avatar
3.73 GPA FTW!
how much for the kit that 200hp is getting? I would love that....pm me if you want bill
'05 3.5se
Stock
Old 07-04-2009, 12:15 AM
spike228's Avatar
Mark of Shame
There's just one problem with the plastic scotch taps. The BCM wires are tiny. You risk snapping the wire or making bad contact if you use those, unless of course there was some other size of that that I was completely unaware of.
My audi DRLs are hooked up to the dome lights and I am actually using the scotchlocks.....I am going to eventually solder them because a quick nudge would make the relay flicker like mad. Just a heads up.
The best place I found to mount another switch is the fuse door. Although I am using a flush-mount switch for that.
Old 07-04-2009, 12:20 AM
No More Nissans....
Well ScotchLoks come small enough to tap into 22AWG wire. They are EXTREMELY hard to find tho. But i have some lying around. And it makes a remarkable connection. And m_tuner: even I dont know how much my kit is lmao
Old 07-04-2009, 12:24 AM
bt2580's Avatar
'Harmony'
True on the Scotchlocks...and one of my main concerns with using them. All of the wiring that I did in my car is cut and tap rather than using quick taps. But since I am trying to build this for the guys that are not so electrically inclined, I am having to resort to using them...
Did you use the standard blue Scotchlocks? 3m does make them in a couple of different sizes. I would be using the ones that are made for 22-16g wire.
As to the mounting location, the fuse door is my first choice, or all the way at the bottom of the panel with a rocker.
Old 07-04-2009, 01:13 AM
No More Nissans....
I may put it on the bottom. And the last time I used VLED's strips i had to find the 22awg taps and it took forever lol. Its good that you found the right ones Bill. I know they are not easy to come by lol
Old 07-04-2009, 01:26 AM
spike228's Avatar
Mark of Shame
I've been using the standard blue ones. I haven't seen them in any other size. Guess they're rare like 200hp said.
I chose the fuse door for one reason. If I ever want to "undo" the mod, the fuse door is cheaper to replace than the entire lower dash panel. That and it's reasonably within reach.
Old 07-04-2009, 01:37 AM
No More Nissans....
Well Spike you can to to an Autozone and pick up the variety pack and it has the 22awg taps in it. And lots of other sizes as well lol.
Old 07-04-2009, 01:38 AM
bt2580's Avatar
'Harmony'
Yes, they are available in a smaller size. I have either seen them in red or black.
That is exactly why I would choose the fuse cover myself. It is a fairly inexpensive piece to replace if selling the car or getting rid of the mod down the road.
