OBD scanner for ABS? - Nissan Forums : Nissan Forum
post #1 of 6 Old 07-24-2009, 03:07 PM Thread Starter
Hey guys,
I've got an '02 2.5S and the ABS started wigging out after I did some maintenance (axles, bearings, rear hubs, rotors and pads).
Under anything more than extrememly light pressure on the brake pedal I get a cycling of the ABS. Maybe 10 pulses, then back to normal for a few feet then antother series of pulses. I'm pretty sure that one of the wheel speed sensors is acting up and I would like to isolate which one.
So I was wondering, is there an over the counter code scanner out there that can pull the ABS codes on our cars?
The closest dealer to me is 3 hours away and the last time I had it there it turned into a huge engine replacement fiasco, so if I can avoid that route, I'd feel much better.
So is there a code scanner that can pull ABS codes?
Cheers
Brett
Brett
Soloyosh is offline
post #2 of 6 Old 07-25-2009, 11:17 AM
2010 2.5s Sedan
jimnolimit's Avatar
you probably disconnected/damaged the wire to the wheel speed sensor while doing the work .
autozone reads codes for free .
you could try pulling out the ABS fuse until you get the problem fixed .
good luck .
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
jimnolimit is offline
post #3 of 6 Old 07-25-2009, 02:04 PM
Boomer
liljohnny's Avatar
Quoted: 2 Post(s)
I hate to tell you this but to the best of my knowledge, you'll have to g to the dealer to get those codes read. I had the same problem and tried several scanners but they couldn't isolate the problem other than saying it was an ABS problem. I'm not saying there isn't a scanner out there that can do it but it won't be any over the counter scanner....
Canucks Rool!
2002 3.5 Ruby
Blacked Out Chrome
Feedback Thread
http://www.nissanclub.com/forums/ven...ck-thread.html
liljohnny is offline
post #4 of 6 Old 07-25-2009, 07:31 PM
Quoted: 1 Post(s)
johnnys right, dealer only bub. The only scanners I've seen that will even reccognize asian abs cost thousands of dollars.
PbLead is offline
post #5 of 6 Old 07-31-2009, 05:45 PM Thread Starter
After digging through the service manual, I found a way to get ABS codes without Consult-II.
1. Drive over 20mph for 1 minute.
2. Turn ignition off.
3. Ground pin-9 of the data link harness
4. Turn ignition on. (Do not hit the brake pedal or start the engine)
5. After 3 seconds the ABS will start flashing two-digit codes.
Looking at all the stuff you can do with the Consult-II though it's be nice to have but at $7000 not really an option.
Cheers
Brett
Brett
Soloyosh is offline
post #6 of 6 Old 08-10-2009, 10:08 PM Thread Starter
Even though it was the LF wheel that the ABS was cycling on, the Code given was 36 Rear Left Wheelspeed. I'll order up a new one post if that fixes it.
Brett
Soloyosh is offline
