repack wheel bearing - Nissan Forums : Nissan Forum
post #1 of 10 Old 09-03-2009, 12:30 PM Thread Starter
Quoted: 8 Post(s)
i have a altima 2004 model i notice that my wheel is roaring. so i called my dealer to repack the bearing he told me that it will cost you around $800.00 plus labor. bcuz in altima you can't repack the bearing you need to replace the hub and bearing is this thing right ?? this is what dealer told me .... its rip offf ............
did anyone here repack the bearing in altima ...
asis975 is offline
post #2 of 10 Old 09-03-2009, 12:38 PM
Super Moderator
4DZC's Avatar
Quoted: 368 Post(s)
iTrader: 33 reviews
There is a big difference in which one it is. Front or rear? Yes it ie correct to replace the bearing altogether. If it is the rear, simply replace it yourself....the front is diff....only because it is pressed into the steering knuckle, but you could seperate the steering knuckle and take it to a dealer or other shop, have the old bearing pressed out, and new one pressed back in. 800.00 is pure horse poo poo. lol I did my own, as always there is a 1st time for everything. Went smooth as butter and had the satisfaction of knowing I did it myself....
4DZC is offline
post #3 of 10 Old 09-03-2009, 12:52 PM Thread Starter
Quoted: 8 Post(s)
roaring sound comming out from both rear wheel. is the bearing pack in side or is it open bearing. if its open bearing i can simply clean it and apply some wheel bearing grease.
asis975 is offline
post #4 of 10 Old 09-03-2009, 02:19 PM
Quoted: 3 Post(s)
no there sealed wheel bearings
ALTIMA2.5SL is offline
post #5 of 10 Old 09-03-2009, 09:01 PM
Quoted: 2 Post(s)
the bearings are sealed you dont repack them. theyre around 80 bucks at a part store. if youve changed brakes before then you should be able to change the bearing
02 3.5 SE Auto, Silver/blk lthr, Tecnafit SS lines, Nismo CAI, Unorthodox UDP, Stillen upper strut bar
tripod is offline
post #6 of 10 Old 09-03-2009, 10:26 PM
Winner March 2010 NOTM
hattrick3518's Avatar
Quoted: 3 Post(s)
i just got my pass front bearing and hub replaced for half of that..
hattrick3518 is offline
post #7 of 10 Old 09-08-2009, 03:41 AM
Dealer is full of crap. Take it somewhere else. I did my rears in under and hour for both.
My Sentra Ser had a front go I think it was 225cad and 2 hours labour. I now own a press so I will do my own when the time comes. The bearing for the front was like 8 bucks 26 for a set of 4.
AceCombat is offline
post #8 of 10 Old 09-08-2009, 06:22 AM
Super Moderator
4DZC's Avatar
Quoted: 368 Post(s)
iTrader: 33 reviews
Can you share info about your press? Interested in getting one.
4DZC is offline
post #9 of 10 Old 09-08-2009, 12:01 PM
Mountain (MTN5720) 20 Ton Hydraulic Press with Jack # 5720 - Compare prices, reviews, user opinions - Shopper.com
Exactly the same as this except mine is yellow and was free. I got it from a garage that was going out of business along with a portable car lift. I love it. Except it's a pain in the ass if you want to do exhaust work. Has a bunch of cross beams that get in the way of long pipes.
post #10 of 10 Old 09-08-2009, 12:06 PM
Super Moderator
4DZC's Avatar
Quoted: 368 Post(s)
iTrader: 33 reviews
Thanks, appreciated.
4DZC is offline
