Ok so the manual says 5 quarts of oil w/ filter change, but I found this http://www.infinitihelp.com/QR/04G35.pdf same engine and they call for 5 quarts. What do you guys do when doing oil changes. Kinda frustrates me that .5 quart leftover in the 5 quart jug.
2005 Altima 3.5 SE
Sheer Silver/Frost
I buy the 4.4litre (4.65qt) PennzPlat and dump it all in when doing an oil/filter change. Shows up just barely over the full mark on the stick.
'03 Altima 3.5SE MT
Avg MPG calculated over last 42397 miles: 26.423mpg
Best/Worst MPG calculated: 32.294mpg / 22.521mpg
Hmm well is .5 quarts significantly overfilling? I'd rather waste .5 quarts of oil then mess up the car.
1/2 quart isn't significant. I usually go with 5 quarts in case the car suddenly feels like burning half a quart. It usually doesn't, but you never know with the VQ.
'03 Volkswagen Passat Slammed Wagon 1.8T current
'08 Titan 4x2 sold
'02 Altima 5MT sold
'02 Altima 4AT sold
'96 Pathfinder 4x4 sold
'83 280ZX-T sold
When I change my oil and filter, I put in 4.5 qts, start the engine and let it run till the oil light goes off. I let the car sit for about 15 minutes, then check the dipstick and add oil until it reaches the full mark. I also recheck after letting the car sit over night. Add oil if it isn't at the full mark. Depending on how much of the old oil is drained, it takes about 4.6 to 4.8 qts. I save the left over oil for the next oil chage.
I do 4.5 but I usually need the other .5 before 3000 miles is up. I guess I could just overfill it a little. I dont have any cats to worry about hurting anyway
Or just check the dipstick after you pour the 4th quart. add to 4.5, check again. is it at the ideal level? add more if the answer is no.
Mods:
| there's a tube on the throttle body | gots some fogs too | got some sounds | HIDzzz | some metal thingy | Nismo exhaust | sport grill | NIZMO WHEELZ /Stikcy as shit tires | Fck the prop rod | header | JIHAD MIRRORS | some metal bar | LEDS | DROPed | some rubber thing | pulled out a chunk of metal | CALIPER PAINT | more metal rods |
I use ~4.5 qt and check the dipstick. I add the other half quart around 4k miles and change between 6.5-7k miles depending on the oil analysis that I do every at 6.5k miles. I basically change oil twice a year, use full syntheic and puralator pure one filters. I've had several oil analysis done at Blackstone that support my schedule, it is what is right for me, I don't know what it right for anyone else nor do I suggest anyone follow what I do. Driving habits, enviroment, oil and filter type and so on all play a part.
Just enough mods to make it mine.
