Switching to synthetic oil on High mileage Altima - Nissan Forums : Nissan Forum
Old 11-10-2009, 04:35 AM
I have a 2005 Altima with the 2.5L engine. I am right at 122,000 miles and thinking about switching to the Mobil 1 High mileage synthetic oil 5W-30.
Here is the problem, my local Walmart does not carry 5W-30, only 10W-30.
Is it OK to use the regular Mobil 1 synthetic oil on a 122,000 mile engine? I currently do not have any leaks, but have heard that the small molecules in the synthetic oil can find small holes in worn gaskets.
Old 11-10-2009, 06:15 AM
You'll be fine..
-237K miles on my 94 Legend and I put her on synth at 200.
Old 11-10-2009, 06:20 AM
I hope it works since all the deals involve 5 quarts of Mobil 1 synthetic oil and a filter included.
Old 11-10-2009, 01:41 PM
Mikeyb's Avatar
Shift_Emotions
Check with Advanced Auto or Autozone.
2003 Polished Pewter Altima 3.5 SE 4AT w/ SE-R Tails, 30% Tint, Front and Rear Irotors Drilled/Slotted Rotors, Goodridge SS brakelines, ATE Blue brake fluid, Redline Synthetic Power Steering Fluid, Eibach Prokit, KYB struts and shocks, Yokohama S Drives, Blizzak WS-50s, and B&M Hi-Tek Trans Cooler. Parked for now due to timing chain...
Old 11-10-2009, 02:50 PM
hattrick3518's Avatar
Winner March 2010 NOTM
i will be switching to synthetic at my next oil change (108,500). you should be fine, if not better off
Old 11-10-2009, 03:29 PM
i think it would be pointless since synthetic is supposed to protect ur engine for the future aka high mileage so i guess you can say "the damage has been done:, why not just get igh mileage motor oil, whats the company that guarantees ur engine up to 200,000 miles or something?
Old 11-10-2009, 03:37 PM
because synthetic is cheaper than what i am paying for conventional now, that's why i'm switching anyways
Old 11-10-2009, 04:16 PM
Penguinchit's Avatar
Moderator
I've heard that since synth is so much finer, if there are any places that would leak with synthetic but don't leak with conventional, the new oil will let you know...
05 3.5SE AT
Stillen lip - Berk V2 - Vogtland springs - muffler neutered - Racingline FSTB
Ate super blue fluid - ebc yellow stuff front pads - f/r kinetic drilled rotors
RTP SS brake lines - Fibre Custom eyelids - ddmtuning 5000K lows & fogs
BT Design underhood light kit - NWP VIAS delete - SE-R style tails - Racingline y-pipe & hi-flow cats
Old 11-10-2009, 04:23 PM
nismos14's Avatar
§è~® f®ÈÄk
iTrader: 24 reviews
^ wtf kind of conventional oil are you buying??
I changed it over on my maxima, @ 140k miles and I had leaks galore.
Old 11-10-2009, 04:30 PM
Well, I e-mailed Mobil 1 to see what they have to say about it.
You can check with your local Autozones for the Mobil1 HM 5W30, you can switch to the Classic Mobil1 motor oil without issue.
I never did check at Autozone since they are usually a little bit pricey, but I will probably just get the regular synthetic oil with the Mobil 1 filter.
Old 11-10-2009, 05:17 PM
saywat?'s Avatar
is it tru that when a car reaches high mileage (whenever that is maybe 100k) u should go to a heavier oil weight like 10w-30
"Sorry Gramps, My Altima's Nicer Than Yours"
"I would like to apologize in advance for being brutally honest!"
MODS:
- Cargo Net retrofitted in the trunk
- 10w HID Converted Dome Lamp
- 8w HID Converted Door Lamps
- Removed OEM FogLight Covers
- Relocated "Special Edition" badge
- Custom Floor Mats with visible "Special Edition" Logo
Old 11-10-2009, 06:48 PM
i have heard this, but also that after the first change, those leaks should now be filled by the new synthetic. so yes on the first change, there will probably be leaks. however after that, on the next change should coat and fill in those leaks?
i have been using valvoline premium conventional, picking it up at checker auto. i get the gallon jug 1@$16.99 and then an additional qt 1@$3.89.
comes out to $20.88 then the filter is $6-$7. plus tax is usually around $30?
$20<$20.88, lol i know its not much, but for the price i want to try and switch to synthetic. however if there are enough horror leaking stories then maybe i'll stay conventional
Old 11-10-2009, 09:05 PM
wow this forum is so uninformed and misled it's quite puzzling.
I like how most of the posts in here are incorrect.
BITOG is something you all need to read.
Welcome
Old 11-11-2009, 12:04 AM
Welcome
i have been on there few times, but for you to just tell us all to read the whole forum then i dont think any of us have time to do that.
if you could clear up some of the questions we have, instead of just telling us we're misinformed and not stating why... we would appreciate it
Old 11-11-2009, 05:28 AM
altjt02's Avatar
zoom zoom
iTrader: 3 reviews
Synthetic may find leaks at first. As long as your gaskets aren't too far gone, tho, those leaks may disappear. Synthetic lubricates the gaskets better and can make them swell and actually stop leaks. Its really kind of a shot in the dark for some really high mileage vehicles, tho.
to the OP: I would say at 122k you should be ok. especially if the vehicle was well maintained. I switched at about 94k with no problems.
Joe-
'02 3.5SE 6MT HLSD (SOLD Nov. 2011)
1/4 mile: 14.29 @ 101.33, 2.29 60' (5MT)
'06 Mazda 3s GT 5MT - Current DD / autox car
Dunlop Star Specs, Mazdaspeed Catback
