this is just another step on my never ending quest to get consistent heat....i bought a tsat from autozone earlier thinkin it would b a pretty simple job but it seems a little more then that i got these directions but was lookin for sumthin a little better or summore tips
1Drain the coolant from the radiator and store it in a proper container. Take the negative battery cable from the terminal.
Step 2Disconnect the radiator lower hose from the engine coolant inlet side. Take out the engine coolant inlet and the thermostat.
Step 3Install the new thermostat with the entire circumference of the flange fitting securely inside the rubber ring. Make sure the jiggle valve is facing up with a deviation of the position plus/minus 10 degrees.
Step 4Use Genuine RTV Silicone Sealant or an equivalent product when installing the temperature sensor for the engine coolant. Apply a mild detergent to the O-ring when setting the heater pipe into the housing.
Step 5Refill the cooling system with the appropriate type and amount of coolant. Reconnect the battery ground.
Step 6Start the engine and allow it to run for several minutes. Check the system for coolant leaks.
AND WAT DOES APPLY A MILD DETERGENT MEAN....COULD U JUS OIL THE O RING???
