Hard to start - Runs Great! - Nissan Forums : Nissan Forum
post #1 of 26 Old 02-23-2010, 02:26 AM Thread Starter
Super Dave
I have a 2005 3.5 V6 Altima. 130K miles. Recently did the second time plug change and is about ready for the timing belt to be done.
On ocassion i am expierincing a long cranking sequence to get it started. Five to seven seconds long in some cases. It has no pattern, no matter if engine is cold or hot. Once started it runs great, no missing or nothing. Any ideas?
Super Dave is offline
post #2 of 26 Old 02-23-2010, 02:29 AM
There's a brake pedal?!
SexyBlackonBlack's Avatar
perhaps the starter is going bad?
SexyBlackonBlack is offline
post #3 of 26 Old 02-23-2010, 02:42 AM
ALTIMAX22's Avatar
altimas dont have timing belts and i would prob agree with the starter going bad
ALTIMAX22 is offline
post #4 of 26 Old 02-23-2010, 02:45 AM Thread Starter
Super Dave
The starter that is turning the engine perfectly fine without any hesitation? It doesnt seem to skip a beat. It engages and turns the engine right away. it's the engine that seems to have a problem taking off after the first two seconds of key ignition, and again it's not all the time. Just whenever it feels like doing it.
post #5 of 26 Old 02-23-2010, 02:48 AM Thread Starter
Super Dave
I just fixed my xterra and it has a timing belt on a V6. Altimas must have a chain?
post #6 of 26 Old 02-23-2010, 03:18 AM
iTrader: 3 reviews
Yeah, the VG33 in your Xterra has a belt. The VQ35 has a chain, and is definitely a more involved job.
Not to undermine you, but have you checked the battery lately?
digitalbow is offline
post #7 of 26 Old 02-23-2010, 04:03 AM Thread Starter
Super Dave
I haven't but it's a start to eleminate the source. I would think if it was the battery it would be more of a slow, weak crank type of start.
Mine cranks hard and strong with a longer duration to self run.
post #8 of 26 Old 02-23-2010, 06:35 PM
there are several things that can effect start up.
battery, starter, shit even if the fuel pump is going bad it could cause it.
Check the battery first, and then go from there.
i still say starter.
post #9 of 26 Old 02-24-2010, 12:21 AM
2010 2.5s Sedan
jimnolimit's Avatar
put the car in the on position (with all lights lit up on dash) but don't start it for 10 seconds , then see if it starts up right away . it could be the fuel pump .
another problem could be the crank/cam sensor , are you getting a check engine light ?
jimnolimit is offline
post #10 of 26 Old 02-24-2010, 01:49 AM Thread Starter
Super Dave
I have an OBD, no codes.
post #11 of 26 Old 02-24-2010, 05:50 PM
my buddy just had this problem mechanic charged him 250 to find and eliminate the problem witch was his maf sensor wires where screwed up. something about the signal from the MAF. idk for sure. he followed the wires and noticed something wrong and ran all new wires from the maf. he didnt get a check engine. and it only was fed up on start up. hope it helps.
03 Nissan Altima 2.5S/SL Champagne Mist Metallic EY1
MODS:TINTS,3.5 EXHAUST,3.5 REAR BUMPER,RACINGLINE F&R SPRINGS AND MMIS,KYB GR2S,EBAY CAI,XS POWER HEADER,LEATHER SEATS,CUSTOM GRILL(HOME DEPOT FTW),G35 7 SPOKE 18'S,DEBADGED,8000K LOWS,6000K FOGS,ANGEL EYES,BLACK HEADLIGHT AND TAILLIGHT HOUSINGS,HIFONICS COLOSSUS 3200WATT AMP, 2X HIFONICS OLYMPUS 12'S.
RECALLS: ECU RETUNE,NEW REAR SUBFRAME,AND LAST BUT CERTAINLY NOT LEAST A NEW FREAKIN ENGINE(TY PRECAT)
KOTEKPL is offline
post #12 of 26 Old 02-26-2010, 04:39 PM
Quoted: 2 Post(s)
Wow, I've been having this same exact problem.
ajones7279 is offline
post #13 of 26 Old 02-26-2010, 05:22 PM
Prepare to be VQmized
Ctrl-Altima-Del's Avatar
I'm with jimnolimit....sounds like it might be something to do with an initial lack of fuel pressure. I like the key on, wait, then start sequence...I do it all of the time anyway just to ensure a quick start.
My wifes VW Beetle runs the fuel pump when the drivers door is opened....even before you put the key in the ignition.....those German engineers are sly.
'14 Tundra DC SR5 TRD 5.7l Avg MPG 17.6MPG
Traded : '03 Altima 3.5SE MT Avg MPG 26.423mpg 325000KM
Ctrl-Altima-Del is offline
post #14 of 26 Old 02-26-2010, 07:43 PM
Quoted: 2 Post(s)
Suspected mine to be a failing battery. Earlier it drained on me and I had to get a boost. Bought a new one and haven't had a long start since.
post #15 of 26 Old 02-26-2010, 10:05 PM
Still #1
Leathe of Heaven's Avatar
iTrader: 24 reviews
Crank/Cam Position Sensor. Had the same intermittent problem. Until it finally died. Then the car wouldn't even turn over.
2011 Mazdaspeed 3 current
'03 Volkswagen Passat 1.8T sold
'08 Titan 4x2 sold
'02 Altima 5MT sold
'02 Altima 4AT sold
'96 Pathfinder 4x4 sold
'83 280ZX-T sold
Leathe of Heaven is offline
