3 errors codes - Nissan Forums : Nissan Forum
post #1 of 5 Old 03-08-2010, 03:31 AM Thread Starter
3 errors codes
So I haven't used my car for the last week. I had removed the gauges cluster to create a new overlay but when I installed back everything, I have 3 codes:
P1211
P1001
P0462
All at the same time after not using the car for a few days. I checked on the web... The first one seems to refer to the ABS/TCS module and the last to the fuel sensor. I didn't found anything about the one in the middle. I think this may be in link with the fact I disconnect the cluster but everything is well connected so any clue ?
Thanks !
wsimard is offline
post #2 of 5 Old 03-08-2010, 04:08 AM
Low & Fast...
Blubird's Avatar
Quoted: 2 Post(s)
Did ya disconnect the battery before you remove the gauge cluster? Try disconnecting the battery for 15 minutes then reconnect it, and the codes should reset.
06 SE VQ 5spd sleeper ll...
Blubird is offline
post #3 of 5 Old 03-08-2010, 04:22 AM Thread Starter
No I didn't disconnect the battery... also the car refused to start after leaving the lights on for around 5 minutes (with the fogs). I waited for another 5 minutes and it finally started. If I didn't disconnected the battery, may I have damaged the ECU by disconnecting/reconnecting the cluster ?
Also, I tought that checking the codes with the "key-on + 3 seconds + 5 floor gas + 7 seconds + floor for 10 seconds" is supposed to reset codes. I am right ?
Thanks !
wsimard is offline
post #4 of 5 Old 03-08-2010, 04:30 AM
Low & Fast...
Blubird's Avatar
Quoted: 2 Post(s)
No the ECU just thinks there was some kinda failer in the system. Try disconnecting the battery.
Blubird is offline
post #5 of 5 Old 03-08-2010, 05:53 PM Thread Starter
I didn't know I have to floor the gaz during 10 seconds to clean codes while in SES codes mode. Easier than disconnecting the battery (even if disconnecting is easy too )
Thank you !
wsimard is offline
