Clatter/rattling noise when starting a 2.5 SL - Nissan Forums : Nissan Forum
Old 06-10-2010, 03:07 PM
When starting our 2.5 SL in the morning it will often clatter or rattle for about a second or less. I've searched the forum and found a couple of suggestions. One is that the VTC gear on the intake cam is making the noise and the other is that the cam chain tensioner is slow in filling with oil (i.e. hydraulic pressure) and it is causing the noise. Sometimes it rattles when we first start it and other times it does not. Once you start the engine, then turn it off it, then restart it, it nevers rattles.
I can live with it but my wife hates it and if the wife ain't happy, nobody's happy.
Which problem is most likely to be causing the noise?
Thanks,
Hap
Old 06-12-2010, 05:23 AM
carlson_mn's Avatar
Registered Idiot
Possibly low on oil will make the top end of the V6 makes some clattering noises for a bit I've heard, not sure about the 2.5L. Check it out after it sits for at least an hour.
2006 3.5SE 5SP Sonoma Sunset
NWP Spacers /Racingline Y-pipe / No muffs / Vogtland Springs/KYB GR2s/ RL FSTB / HID 6k Lows and 5k Fogs / M3 Roof lip/ Kenwood dpx503/ Infinity 5350A/ Kappa components and IDQ15 sealed sub, JBL1200.1
14.5@98.8 2.37 shitty 60'
SOLD Aug 2012
Replaced with 06 CTS-V
Old 06-12-2010, 08:24 AM
BT's Avatar
BT BT is offline
Super Modder
iTrader: 15 reviews
2.5's do have that issue as well after the oil settles.
2 options...
Get a different car...
Start the car for the wife
Frankensteined 2002/3/4 3.5SL
QR to VQ swap
Other Pics
My NC Garage
My Feedback Thread...
Old 06-12-2010, 10:42 AM
Oil level is not an issue. I've ruled that out already.
Old 06-12-2010, 02:10 PM
Tarik's Avatar
Tismoed 1 part at a time.
FIXED
2 options...
Get a remote starter installed
wolfpacrules :
I am doing oil change and when I pulled out the oil filter, only about 1/3 Qt of oil came out.
Sentinal: Ummm....are you trying to do an oil change through the filter???
Old 06-12-2010, 03:18 PM
Yeah,...thanks for the technical advice. Nevermind, I was looking for someone with experiance on the subject.
Old 06-13-2010, 05:24 AM
I have the same issue. I have O2 Altima 2.5 it has been making that noise forever now I took it to the dealer when it was under warranty and after they could never duplicate or find anything wrong with it. I hate the noise but what to do...car has about 114000+ miles on it. If you figure it out let me know good luck
morvilleCunningham
Old 06-13-2010, 06:36 AM
My 2.5 does the same thing.
Dark Slate 2008 Altima 2.5SL
No car note = #winning. New set of Nexen 5000 Tires, Alpine CDA-9887, Kenwood KAC-X10D & KAC-X40, JL Audio CS213RGW1V, Racingline strut tower brace, 35% Tints, Stillen Rear Sway Bar. Hushmat on trunk, side panels and rear deck.
Old 06-13-2010, 09:24 PM
i have a 3.5 and a machanic said that it was something called a timing chain, and that only the dealer can fix it.
Old 06-13-2010, 09:29 PM
Well some older 3.5s have an issue with the timing chain tensioner wearing out. That may be what your mechanic was referring to. Search for it, you'll find more info.
Old 06-13-2010, 09:33 PM
yup mine was my timing chain
02 Altima 2.5
4-1 Headers | Blacked out trim | 6k HIDs (soon to be 8k) | just chillin want more mods
Old 06-13-2010, 11:59 PM
Tarik's Avatar
I have the same issue. http://www.nissanclub.com/forums/eng...ne-rattle.html
Old 06-14-2010, 01:41 PM
GirchyGirchy's Avatar
Who wants a body massage?
2 options...
This. It's some sort of valvetrain noise. Mine's louder and lasts longer in cold ambient temperatures. Every 2.5L Altima I've driven does it.
I quit worrying about it when I got my oil analyzed, they found no abnormalities in the oil.
Old 06-14-2010, 06:51 PM
This one didn't do it until it got a remanufactured replacement engine put into it. The original engine died when a oil change place forgot to tighten the oil drain plug and my wife lost all the oil on the interstate. It shouldn't rattle.
Old 07-10-2010, 12:42 PM
No more rattle when the engine starts. I changed the VTC gear and that fixed the problem. I also adjusted all the valve clearances because I found over half to be either out of spec or borderline.
Now the engine starts without any rattle and it runs VERY smooth.
Thanks to those who's input was sincere.
Hap
