2005 Altima Door Panel - Nissan Forums : Nissan Forum
post #1 of 3 Old 07-19-2010, 07:22 PM Thread Starter
Quoted: 2 Post(s)
Question 2005 Altima Door Panel
I have an 2005 Altima SL which has a rattling noise coming from front passenger side door when window is down. I have searched previous threads but only found video and pictures for the removal of 2002-2004 models door panels.
Does anyone have pics of where to find the necessary screws and bolts to get panels off or a video would be great for the 2005 model year.
Thanks for any help at all !!!!!
Luca is offline
post #2 of 3 Old 07-19-2010, 10:59 PM
It's actually pretty similar..I've taken my door panel off a few time. Just take a screwdriver and pop out the plastic behind the handle to open the door is and you'll see a screw I think. Then there's like a 10mm bolt under where you grab to pull the door closed.
You'll also need to pop off the thing that rolls up the windows and disconnect them and also disconnect the courtesy light at the bottom by just pulling from the bottom and disconnecting the connection there.
And then you should just have to pull and pop the panel off.
I can't remember if I'm missing a screw somewhere but it isn't all that hard.
Archenemy_6 is offline
post #3 of 3 Old 07-20-2010, 12:36 PM
UzumakiNaruto's Avatar
Quoted: 8 Post(s)
happen to me too..i had a video in a thread a while ago about it. i took off the door panel and the door buttons and i tighten 1 nut and problem solved.
Altima 2013 2.5 SL
Mods: HIDs 5000k low beams(XB35Bulbs From TRS),Racingline front strut bar, BT Led footwells front and back, CFL Truck lights, yellow film on parking lights, LED's license plate lights, LED Foglights 6000k 20watt,Installed led DRL's ,Front Stillen Lip (paint matched) and Enkei T6S 18 in.
Next mods : Mud guards, tires/rims and Short Ram intake.
Chemical Guys and Mothers products to keep it clean.
UzumakiNaruto is online now
