Unplugging the Crank Position Sensor - Nissan Forums : Nissan Forum
post #1 of 5 Old 07-21-2010, 06:39 AM Thread Starter
Wow, I feel like an idiot.
I read up on the FAQ on how to replace the crank position sensor and I was having no luck with it no matter how much I tried.
(FAQ: http://www.nissanclub.com/forums/f-q...-5-altima.html)
Turns out I was pressing on the clip incorrectly. I guess I didn't look at the pics closely enough. But hopefully this pic helps anyone else that has problems getting the pug disconnected. I wanted to add this to the FAQ thread, but can't post any replies.
MaximaZero is offline
post #2 of 5 Old 07-21-2010, 10:49 AM
2488cc
nadjkovic's Avatar
Whenever I tried replacing mine, I got the connector off.. but the actual sensor wouldn't come out of the motor.
'06 G35 Sedan 6MT
- Z1 clutch & flywheel - Z1 intake - dumped exhaust under driver's seat -
03' Alti 2.5S 5MT, more of the car..
The QR25DE Modding Information Thread
nadjkovic is offline
post #3 of 5 Old 07-21-2010, 02:42 PM
How often do these sensors go out? Are they behind the timing chain?
Gamble is offline
post #4 of 5 Old 07-21-2010, 04:12 PM Thread Starter
@nadjkovic - yeah it's difficult to get enough leverage to pull it out. i had to keep twisting it for a while and then tugging the crap out of it before it would finally pop out.
@gable - the crank position sensors using ht e old plastic design are prone to failure and will likely need to be replaced at some point. i haven't heard of people having problems after switching to one of the new metal ones.
it's on the right side of the engine block. there's a good description of how to find it in the faq i linked to in the op.
post #5 of 5 Old 07-21-2010, 04:38 PM
Do you know what year they switched over to the metal one? I'll look at the link now.
Gamble is offline
