Hello,
I've got a noise coming from the engine area of my car that comes and goes only when I accelerate. The sound reminds me of a rattle snake or a metal vibration. It doesn't do it when the car is in neutral and pressing the pedal or when you remove your foot off the gas when your driving. It seems more noticeable at different RPM's when driving. I also jacked both sides of the car up with the car in drive and stll didn't hear the noise. It does it with the car cold or hot.
I've searched the forum, but couldn't find anything that matched my situation. So, any help would be much appreciated.
Look at the heat shield......if it is loose...You are lucky you got so may miles before it broke. Put a hose clamp around it and tight'n it down. Did mind a couple yrs ago ...still going fine.. Just did our POS Oddy as well
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*12 3.5 SR w/Tractor Transmission
*04 Honda Odyssey (9.67mpg)
*04 GTO 6MT(Beater) Gone
Thanks for the feedback. I hope it's caused by a heat shield since that would be a cheap fix using a hose clamp. I'll check it out this weekend and report back.
I looked everything over and have a couple of questions. Are the shields everyone's talking about attaced to the muffler or bolted to the frame. Would the hose clamp be used around the braded portion of the exhaust near the engine?
What I saw was a metal shield near the engine that was close to the braided portion of the muffler. The shield was securely bolted to the frame, but when I banged my hand against it the cover would vibrate against something else. Could this vibrate only when I accelerate?
Where specifically would the hose clamps be used since I couldn't find anything broken loose.
dude i hope u get an aswer for this. i have an 05 3.5 and i get the same noise when i accelerate. when im coasting its good, but always when i accelerate i hear it. keep me updated so i can address this issue myself. thanks.
If you have a short ram intake, then its rattling against the body of your engine bay, and you just need to tuck it in further. Other then that, I am not sure.
mine was the shielding directly connected to precats and the y pipe.
i went under the car and just looked at all my exhaust heat shields. i noticed some of the factory welds had broken connecting the sheet metal looking heat shields to the exhaust. this was causing the vibration/rattle noise.
i went to advance auto and got some of the biggest hose clamps. I clamped them around the heat shields. the noise went right away.
hope this helps..
2011 Nissan Altima 3.5 SR - llumar CTX tint(30% front and 15% rear) and avery nano fusion clearbra(bumper, hood, mirrors, fenders)
2005 Nissan Altima 3.5 SE -
Nismo exhaust/y-pipe/ HFPCs/cross drilled & slotted rotors /gransport6 carbon ceramic pads/Transgo shift kit with sonnax valves/ 235/55 17 Yokohama s-drives
waiting to install: racingline MMI
