Where is the mileage number stored? - Nissan Forums : Nissan Forum
post #1 of 46 Old 03-23-2011, 01:18 PM Thread Starter
Registered Organ Donor
Question Where is the mileage number stored?
I've been having issues with my gauge cluster and want to replace it. Is the mileage stored in the cluster or would my mileage appear on a replacement cluster?
Tico305 is offline
post #2 of 46 Old 03-23-2011, 01:23 PM
ZERO MILES SINCE 2013
coconutt's Avatar
Quoted: 89 Post(s)
I believe it's stored on the cluster.
BTW what's wrong with your guage cluster?
just found out that in 2 hours I will be dressing up like justin effing bieber and lip syncing to one of his songs at a damn pep rally in front of the entire school.....fml
coconutt is offline
post #3 of 46 Old 03-23-2011, 01:39 PM
Dragon Slayer
SERendipitous's Avatar
Quoted: 22 Post(s)
Your correct mileage will appear on the replacement cluster.
2006 Black SER 6MT..
2012 Slate G37X 7AT..
SERendipitous is offline
post #4 of 46 Old 03-23-2011, 01:39 PM Thread Starter
I took the needles off and there doesn't seem to be a way to reset them back to how they were. I'm a perfectionist when it comes to these kind of things and knowing the needles are off just bugs the hell out of me...
If it's stored on the cluster is there a way to set it?
Tico305 is offline
post #5 of 46 Old 03-23-2011, 01:44 PM
coconutt's Avatar
Quoted: 89 Post(s)
Good to know.
coconutt is offline
post #6 of 46 Old 03-23-2011, 02:08 PM Thread Starter
oh i missed that...thanks a lot guys
Tico305 is offline
post #7 of 46 Old 03-23-2011, 02:20 PM
flAt an curvy
Flat Black U13's Avatar
to calibrate the needles, while its on you gently move it to top high speed till it stops, then back to the starting point.. i believe u do this twice, but just go once an seee if it works.. mine was being retarted too.. ive gotta replace it
High Mileage Club 377ksooo blaque
Flat Black U13 is offline
post #8 of 46 Old 03-23-2011, 02:23 PM Thread Starter
So..what about the rpm needle
Tico305 is offline
post #9 of 46 Old 03-23-2011, 02:26 PM
Shaving My Shoulders
RIZAMAN's Avatar
Quoted: 273 Post(s)
Makes sense...Otherwise fraud would be a whole lot easier.
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
Originally Posted by Penguinchit View Post
All you G owners suck balls.
RIZAMAN is online now
post #10 of 46 Old 03-23-2011, 03:01 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
I am not saying you are incorrect.....but, I had mine replaced under a TSB and they had to put in the correct ODO reading. it was not something that magically happened.
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*12 3.5 SR w/Tractor Transmission
*12 Quest SL
wild willy is online now
post #11 of 46 Old 03-23-2011, 03:36 PM
My little champion...
KeVQ35's Avatar
Quoted: 19 Post(s)
iTrader: 3 reviews
Willy is right. The mileage is stored on the gauge cluster, BUT it's also stored elsewhere (probably in the ECU). The dealership can reprogram your gauge cluster so that it matches the TRUE mileage from your computer.
Since I've been in and out of my gauge cluster and changed the faces a few times, the needles can be calibrated - here's how, I should make a video but I'm busy right now.
This post contains the correct steps, I had left out a NECESSARY step, otherwise things will not work
I am not near my car right now, but if someone can confirm where the gauges go. The fuel and temp goes to the middle. The RPM needle goes to like 2500 I think and the MPH goes to one of the KM/H tick marks -- I can't remember right now.
Last edited by KeVQ35; 07-10-2015 at 03:27 PM. Reason: Ammended to include a REQUIRED step.
KeVQ35 is offline
post #12 of 46 Old 03-23-2011, 05:34 PM Thread Starter
  • PUT THE KEY IN THE IGNITION
  • MAKE SURE IT IS IN THE OFF POSITION (ALL ACCESSORIES AND GAUGES OFF).
  • PUSH THE TRIP COMPUTER RESET KNOB AND KEEP HOLDING IT
  • TURN THE KEY TO THE ON POSITION WHILE HOLDING THE TRIP RESET KNOB
  • THE DISPLAY SHOULD LOOK LIKE THIS "----"
  • RELEASE AND HOLD THE TRIP RESET KNOB
  • THE NEEDLES SHOULD GO TO THEIR RESPECTIVE CALIBRATING POSITION
  • AS LONG AS YOU HOLD THE TRIP COMPUTER BUTTON ALL THE NEEDLES WILL MOVE TO THE CALIBRATION POSITION.
I'll try that as soon as I get a chance, but I'm a little confused. Once I'm done recalibrating...I still have to move the needles? Or do I just leave the needles on and recalibrate and all will be well?
Tico305 is offline
post #13 of 46 Old 03-23-2011, 06:18 PM
2 low 4 fat hoes!!!
TUKO's Avatar
Quoted: 11 Post(s)
your correct mileage WILL NOT show up on thed replacement. The mielage that's on the replacement cluster is what will show up. I suggest getting a cluster with less mileage then your car rather then one with higher mileage.
FULLY BUILT MOTOR AND CUSTOM SUPERCHARGER FOR SALE
http://www.nissanclub.com/forums/par...e-partout.html
2005 ALTIMA SER 6SPEED
-ENOUGH MODS TO WHOOP YOUR ASS!!!!
-THIRD PLACE IN V6 N/A DYNO COMPETITION AT
NOPI NATIONALS 2006.
Originally Posted by swat1279 View Post
Tuko316, that vortec cyclone that you mentioned,ordered 2 and works great. I got great gains Thanks. Oh and your car is sharp dude.
TUKO is offline
post #14 of 46 Old 03-23-2011, 06:26 PM
04-05 Pedal Insert
wild willy's Avatar
Quoted: 58 Post(s)
Out of curiosity, where did you get this information? This is a great place for information.....if you know........Great! But if you are unsure....say that and do not give the impression that what you are saying is fact. Your year may be different....I am not saying it is not....But it is better to cast a little doubt if there is a chance you are wrong.
Just sayin....Bad info can cause someone significant grief.
*Bumper Plugs
Garage:
*12 Quest SL
post #15 of 46 Old 03-23-2011, 06:48 PM
KeVQ35's Avatar
Quoted: 19 Post(s)
iTrader: 3 reviews
You'll have to pop them off and put them where they need to be. The fuel and temp needles should be at half, RPM @ 1500, and SPEEDOMETER @ 50 KM/H.
KeVQ35 is offline
