could not much info on removing and installing this
part. Has anyone done this on the 3.5 2003 altima. This is located on the right side of the fuel rail.
Thanks
I see what I can do about a picture. Its just a small round silver canister on right side of fuel rail. isaw a picture here once now i can find it. I also have
seen it called a fuel pressure damper.
Thanks
The fuel pressure dampers are easy to fix. By the way there are two of them, the other one is under the 3.5 engine cover for the front rail. They tend to leak and you can see the gas on and around them. They can affect the fuel pressure and let air in as well which will throw off the performance of your car. Any DIY'er can do this.
I'm having this problem with mine right now; the one under the engine cover is leaking gas onto my intake manifold. There doesn't seem to be a whole lot of information in regards to these things on the net. Do you have to remove the entire fuel rail to access those things? Is it as simple as just replacing the oring within them?
If they are just plain leaking then yes, you can just take off the 2 bolts and replace the o-ring. Both dampers are pretty accessible, once the engine cover is off you are basically looking at them on the ends of the fuel rails. Should be 2 bolts holding each on.
Ideally you should relieve fuel pressure before doing this by pulling the fuel pump relay/fuse and cranking the engine, but its not a huge deal if the car has been sitting a while. Fuel is still going to come out when you unbolt them, so get some rags or paper towels. There will be an initial gush of fuel and then it should slow down to nothing quickly. I don't think you can just replace the damper because the rubber quick disconnect lines connected to them are sealed onto them, but if you can find the right size o-rings just do that. I see the whole assembly (damper + line) for ~$58 on rockauto.com
You didn't mention that before. Okay, so you have a 2006 Altima SE-R 6 speed manual transmission VQ35DE. But, sounds like maybe you just need a new O-ring on the fuel damper then or maybe a new fuel damper itself.
Cool, thanks. BTW, originally I never mentioned what year model I had; I guess that was an assumption on your part; also my year model is in my sig ;-)
