Please Help 2005 Altima SE SLIP, ABS and TCS come on - Nissan Forums : Nissan Forum
post #1 of 11 Old 05-19-2011, 11:53 PM Thread Starter
2005 Altima SE
issue is that while driving the SLIP, ABS and TCS lights will come on after driving for about 5 mins and when pressing the break it will some times make a gringing sound almost like the abs is kicking in and pulsating.
I took it to my mechanic and I do have the code can't remember what it was but it was the right rear wheel speed malfunction, so he replaced the speed sensor, that didn't work, then replaced the bearing, that worked for about 1 week. It seems to be getting worse, what else could it be? wiring, ABS itself causing the problem, I've already spent $800 and it is still not fixed. Any help would be helpful.
Thanks
ebber is offline
post #2 of 11 Old 05-20-2011, 12:16 AM Thread Starter
The code was C1105
ebber is offline
post #3 of 11 Old 05-20-2011, 12:40 PM
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
It's probably the harness itself, was that replaced?
nismos14 is offline
post #4 of 11 Old 05-20-2011, 01:32 PM Thread Starter
I don't think the harness was replaced, I'll have to check with my mechanic to see, is there a way to check like the voltage or something to see if it could be the harness
ebber is offline
post #5 of 11 Old 05-20-2011, 01:34 PM
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
Not that I know of. I had this issue because of my short shifter, it rubbed against the wiring of the front abs sensor under the hood and chaffed it.
nismos14 is offline
post #6 of 11 Old 05-20-2011, 01:46 PM Thread Starter
Ok thanks Nismo, I was thinking that it has to do with the electrical, there is nothing else back there that would cause the problem. I just thought that the harness was part of the sensor, but I guess not . Once I get his to check that and hopefully the harness is not to expensive I will get him to order one and let you know the outcome.
ebber is offline
post #7 of 11 Old 05-20-2011, 01:53 PM Thread Starter
So I called my local Nissan dealer and they said that the harness is part of the sensor so that must of been replaced as well........oh god here we go again
ebber is offline
post #8 of 11 Old 05-20-2011, 02:35 PM Thread Starter
ok after talking to the parts guy he said that the harness is different and is about $375 canadian. He also checked with one of the mechanics there and they said it could be either that or the ABS controller actuator module which was $1200...LOL.
ebber is offline
post #9 of 11 Old 05-22-2011, 06:32 AM
I had the same issue with another car, it was an abs sensor. The slip, traction control and ABS light were all on. And i couldnt turn TC on, it was stuck off. I just brought it the dealer, and he reset evrything. Probably not your case, but just putting it out there
coreyjrodriguez is offline
post #10 of 11 Old 05-23-2011, 01:53 AM
GunZ2Nv
sim2424's Avatar
I just recently had this issue, and i used a snap-on code reader and measured all 4 wheel speed at the same time and the issue was RR abs/speed sensor. I had that changed and its fine now.
Hope it helps
04 Nissan Altima 3.5 V6SE
sim2424 is offline
post #11 of 11 Old 11-19-2013, 04:08 PM
Autocrossing Cone Creeper
First time that happened to me was last night. Chasing the cause also.
Last month, it started hanging in gear. Third twice, 5th once. Finally got it to Aamco thinking it was transmission related. Vehicle Speed Sensor is what the code pulled yesterday.
Mech cleared the code and last night I get this. I'm going down the path of VSS to see if I can come at this from another angle.
Redirect?
ubjazzed is offline
