Front Passenger Side Axle removal? - Nissan Forums : Nissan Forum
post #1 of 6 Old 06-16-2011, 09:23 PM Thread Starter
Ok, before you die hard members flame me, I have done some searching. I'm not new to forums so I know to search before I make a new thread.
I'm looking for information about replacing my passenger's side axle assembly. I have pretty much all the tools to do it but I wanted to know if there were any hidden unforseen problems before I get started. I ordered the axle the other day and I'm waiting on it to come in so I wanted to have my guns loaded before I break down the Altima. I have another ride but I didn't want to have to use it, for a long period of time, if I happen to run into a major problem. I have a 02' 2.5S.
Are there any special tools required?
Is there a retaining ring that I have to remove before I can pull the axle out?
I know I have to:
1) Remove the wheel/tire
2) Remove the brake assembly, (Can I just get a wire and hang the caliper out of the way?)
3) Dissconnect the lower control arm.
4) Do I need to dissconnect the ball joint \ tie rod ?
5) while I was at it, replace the bushings, if so, what are a good replacement? (moog?)
If I can think of anything else, I'll post it.
Thank you in advance.
Stephen
Oh yeah, pictures would be nice
Bitches come and go but speed is forever
Last edited by GuessWhatMan; 06-16-2011 at 09:25 PM. Reason: left out year and engine size
GuessWhatMan is offline
post #2 of 6 Old 06-16-2011, 10:17 PM
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
You can just hang the caliper off the spring with a tie strap or coat hanger. You do not need to remove the brake rotor.
You need to remove the tie rod end from the hub, the ball joint can stay.
Remove the two bolts holding the strut to the hub.
There isn't a clip or anything that needs to be taken out before the axle will come out of the trans, it just pops out(use a hammer and a pry bar)
The mount on the engine for the passenger side axle is kind of a PITA to get out, but you can do it. Assuming its the same as a 3.5, not sure tho.
Moog is very good quality stuff, i'd go with them.
05SickSer is offline
post #3 of 6 Old 06-16-2011, 11:02 PM Thread Starter
good info
Thanks for the info. Just what I was thinking.
Where do I find the torque setting when I go put everything back together?
post #4 of 6 Old 06-17-2011, 12:20 AM
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Getting a FSM or something like that would say the torque specs. But personally I would just make sure that its all tight and not going to come loose and your are fine. Make sure you have the axle nut as hell, because mine was backing itself loose awhile ago and I had never even touched it before.
post #5 of 6 Old 06-17-2011, 12:37 AM Thread Starter
What is "FSM" Not sure what that means. I'm still a noob to this type of car and I'm learning as fast as I can though.
Oh yeah, very fimilar with that dam nut. I have a 2' breaker bar and the right size socket. Both half inch driven. I think I can break it loose. I've already had to replace that dam bearing twice now. WTF??? Don't get me started with some of the problems I've had.... other than those unmentioned problems, the car is pretty sweet!!!
Thanks again for the help.
post #6 of 6 Old 06-17-2011, 12:43 AM
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Factory Service Manual. I have had my share of little dumb problems too lol, but its been a good car non the less. I thought my wheel bearing was really loose and was going to replace it also, then when i went to take the axle nut off it was already loose and I was like wtf? Tightened it up and the bearing was fine lol.
