How to safely clean a throttle body? - Nissan Forums : Nissan Forum
post #1 of 10 Old 11-20-2011, 04:23 PM Thread Starter
peelman's Avatar
Quoted: 3 Post(s)
What's the second best way to clean the throttle body ( butterfly) when it's still attached to the intake?. When I did my spacers I noticed it was pretty dirty on both sides.
03 Altima S.E 3.5
Mods...Lots.
peelman is offline
post #2 of 10 Old 11-21-2011, 02:36 AM
Biz
VQ'D Sleeper
Biz's Avatar
Quoted: 1 Post(s)
I have read in a few places you want to avoid opening the butterfly with your fingers/tool and spraying with a cleaner. Some say it will damage the TB. However I have used that technique once to clean my TB while it was attached with no issues. I think I used carb cleaner. If I had to do it again I would just remove the TB bolts and clean the TB over some cardboard.
2003 3.5 4AT
Racingline | Nismo | Optima | Weapon-R | Stillen | Raybestos | BT | 4DZC | VLEDS
Biz is offline
post #3 of 10 Old 11-21-2011, 03:49 AM
Ey3CoNz2's Avatar
What I did was I literally took the throttle body of the engine, as in I unbolted it and held it over some cardboard, used a toothbrush and throttle body cleaner and cleaned it. I moved the butterfly valve and sprayed EVERYTHING except for the electrical connections. I literally held it open with my fingers and sprayed and cleaned it some more. It was the easiest way to do it, and sprayed my maf with maf cleaner too.
I had no problems, and wasn't aware of others having problems. You're experience may vary, but it was the easiest and most efficient way to do it AND it have me room to reach in to the engine and wipe away some of the carbon buildup (which now that I think about was not a good idea).
Ey3CoNz2 is offline
post #4 of 10 Old 11-21-2011, 07:38 PM
scorpio02150
scorpio02150's Avatar
Quoted: 12 Post(s)
There's a spray cleaner at your local car parts store, but others on this forum will say to just leave it alone...and certainly NOT to touch it with your fingers, otherwise you'll need to bring it to the dealer to get it reprogrammed.
2013 Infiniti G37x
2004 | 2.5: Brembo Rotors | Akebono Pads |Michelin Energy on stocks|
2002 | 3.5- Car Sold- some parts are available for sale!
Stillen FTB | NWP VIAS Plate | Idle Time Advanced +2 |NGK Plugs |
Berk WAI w/ Apexi | Brembo Rotors | Akebono Pads | 35% Tints |
Eibach Pro Kit | KYB GR2 | Energy Suspension Bushings | RL Rear End Links|
AT S2 Grill | AT Lower Grill | CF Tails | Custom Altima Step Plates |
BT Aux Input | BT Trunk LEDs | 8000K Headlights | 6000K Fogs |V- LEDs |
Optima RedTop | Falken Ziex 912s on stock | 18s RH Evos w/ Pirelli P60s |
Magnaflow High Flow Catalytic Coverter|
Many items are for sale!
1997 Altima: Sold
scorpio02150 is offline
post #5 of 10 Old 11-30-2011, 12:51 AM
Custom User Title Here
Not something I would do but
Put the key in the ignition and turn it to ON (not start), put the car in gear (D) and have someone floor the gas pedal so the buterfly opens, take a rag (maby damp with some cleaner) and carefully clean the sides.... avoid the butterfly.
Regards
KCROSS2519 is offline
post #6 of 10 Old 11-30-2011, 01:25 AM
saywat?'s Avatar
Quoted: 22 Post(s)
^thats the dumbest thing ive ever heard
"Sorry Gramps, My Altima's Nicer Than Yours"
"I would like to apologize in advance for being brutally honest!"
MODS:
- Cargo Net retrofitted in the trunk
- 10w HID Converted Dome Lamp
- 8w HID Converted Door Lamps
- Removed OEM FogLight Covers
- Relocated "Special Edition" badge
- Custom Floor Mats with visible "Special Edition" Logo
saywat? is offline
post #7 of 10 Old 11-30-2011, 01:38 AM Thread Starter
peelman's Avatar
Quoted: 3 Post(s)
Yeah, anyways... I'm not going to bother. When I reinstalled the CAI, no longer have to look at the throttle body, so all good!.
03 Altima S.E 3.5
Mods...Lots.
peelman is offline
post #8 of 10 Old 12-02-2011, 10:14 PM
Ey3CoNz2's Avatar
Regards
No. Simply No.
My way really isn't that bad. If you disconnect and remove the throttle body from the Engine I can't see why it give you trouble if it's cleaned and the butterfly valve is scrubbed.
Ey3CoNz2 is offline
post #9 of 10 Old 12-03-2011, 08:44 AM
Registered Abuser
2809's Avatar
Regards
lol
"I was going to join the spec ops division of the boy scout reserves today, but they said that my tangelo belt in tae-bo and advanced levels of yo-yo warfare training make me over qualified. I guess it's time to talk to some of the other branches and see if they can help me. I hear the fireside girls have a pretty tough unit that has a focus on search and rescue of small mamals."
2005 Nissan Altima 2.5 S in Blue
* KYB GR2 Struts paired with H&R Springs * 5% Tints
* C-Mod Grille * Blacked out chrome trim * OEM Trunk Spoiler with Rear Window Spoiler * Montegi DP5 Wheels * Pioneer AVIC D3 Navi * Philips 4300k HID's * OEM Fogs * White LED Interior * LED license plate lights *SE-R tail lights *Ebay Headers * Ebay CAI w/ K&N Cone
2809 is offline
post #10 of 10 Old 06-22-2016, 07:52 PM
Quoted: 15 Post(s)
If you don't run your vehicle at WOT, there is no reason why the throttle body would get contaminated with oil unless your piston oil rings are so bad that you are burning oil anyway. If that isn't the case, the little dirt that gets past the air cleaner will coat the whole air intake manifold including the throttle body but the computer easily adjusts for any decrease in air flow that that dirt buildup causes. Only if running at WOT will you notice any decrease in RPM because of this. Therefore if you don't run at WOT then throttle body cleaning is unnecessary.
korner is offline
