Terrible engine vibration when in gear and standing still - Nissan Forums : Nissan Forum
 1Likes
  • 1 Post By dfstack22
post #1 of 11 Old 07-14-2012, 01:31 PM Thread Starter
<--the next 4 years!!!
danmark007's Avatar
Exclamation Terrible engine vibration when in gear and standing still
I know one of the engine mounts, if not more, has to have gone bad however I cannot tell which one. Far as I can see they all appear to be fine. When the car is put into either Drive or Reverse and stopped, then engine vibrates terribly...just replaced the serpentine belt because it shook so much it jumped.
Any ideas which mount could be bad? How can I determine which mount has gone bad? I can't drive the car because I'm afraid the belt will jump again and possibly cause more damage.
Thanks in advance guys.
danmark007 is offline
post #2 of 11 Old 07-14-2012, 01:54 PM
ZERO MILES SINCE 2013
coconutt's Avatar
Quoted: 89 Post(s)
Replace the passenger mount to fix the notorious clunking sound. This is the easiest mount to replace.
Replace both front and rear mounts to better the vibrations you're experiencing.
The driver side mount should be fine.
just found out that in 2 hours I will be dressing up like justin effing bieber and lip syncing to one of his songs at a damn pep rally in front of the entire school.....fml
coconutt is offline
post #3 of 11 Old 07-14-2012, 04:20 PM Thread Starter
danmark007's Avatar
Pulled the passenger mount and it was ripped underneath the center bolt. I asked a local Nissan tech over the phone what the likelihood another mount had gone bad...he said last year he replaced 126 of the passenger mounts versus 8 of the next highest which was the transmission mount.
Will post after replacement and ensuring that was the only one that was bad.
post #4 of 11 Old 07-14-2012, 04:24 PM
coconutt's Avatar
Quoted: 89 Post(s)
I was hoping my passenger mount would've solved my vibration issues but not very much. But still better than before.
And the clunking sound was gone at least.
coconutt is offline
post #5 of 11 Old 07-14-2012, 06:03 PM Thread Starter
danmark007's Avatar
Replaced and violent shaking is gone HOWEVER, it's still shaking a bit. Upon inspection the automatic tensioner is vibrating and moving quite a bit. Going to replace that today or tomorrow. Also, the crank pulley appears to be off by about 1mm. Any idea which way it's threaded...clockwise or counter-clockwise?
On a side note, the engine shifts forward or backward when placed into Drive and Reverse. I don't know how much it is supposed to shift it at all, but it appears to be excessive.
post #6 of 11 Old 08-03-2012, 07:53 AM
if vibration stop when car is running, Vibrates while in idle or when you are in the traffic, vibration stop when you put your gear to Neutral, vibration stop when you turn off the aircon, the most likely problem is your timing chain.
williealmilla is offline
post #7 of 11 Old 08-04-2012, 02:12 AM
Quoted: 3 Post(s)
no, most likely alternator clutch binding. Check for belt flop. If belt is flopping it's way more likely to be alternator than tensioner.
halbbd01 is offline
post #8 of 11 Old 08-09-2012, 02:39 PM Thread Starter
danmark007's Avatar
Replaced alternator and noticed significant improvement however there's still a lot of engine movement when engaging gears.
Going to replace front engine motor mount (bow-tie) and see if that keeps it steady. The rear appears to be solid so I don't think it could've gone bad..instead just acting as a pivot point for the front to move up and down.
post #9 of 11 Old 10-18-2012, 02:55 PM
Have you replaced the front mount and was there any imrprovement?
Linaltima is offline
post #10 of 11 Old 01-09-2016, 01:36 AM
Solution
Hey guys, I know this is an old post, but I thought I would provide the solution to this issue for future reference. I just rebuilt my KA24de in my 1995 240sx, and I had similar issues. My car would shake violently when I first put it into any gear, and when the vehicle comes to a stop. During the rebuild, I replaced both my engine mounts, so I new that was not the problem. Also, you should be able to see the engine shaking quite a bit if it has a bad engine mount. I then replaced the transmission mount, and it did not solve it.
Solution:
(This is how I fixed my 1995 240sx with KA24DE engine)
I replaced the idle air control valve, because my old one was broken at some point. The IAC needed to be adjusted to suit my vehicle. Therefore, the TIMING and IAC should be simultaneously adjusted according to the factory service manual. Once I got it dialed in, the shaking was gone.
Basic adjustment procedure:
Disconnect the throttle position sensor
Disconnect the electric cooling fan, turn off heating/AC, and put the car in neutral to put the car in a "no load" situation.
Simultaneously adjust the IAC screw and the distributor to achieve approximately 700 rpm and 20 deg BDC.
Rev the engine above 2000 rpm for around 2-3 mins
turn the car off
re-connect the throttle position sensor and electric cooling fan
crank the car
put in neutral
the car will try to adjust for the changes that were made to the IAC. You will hear the car adjust, kind of a single click type noise.
the RPM should now read approx 750 rpm
rev the engine above 2000 rpm for 2-3 mins
verify that the car is running at 20 deg BDC and at 750 rpm
Put it in reverse, and the shaking should be gone
jimmy.romero likes this.
dfstack22 is offline
post #11 of 11 Old 02-03-2016, 01:12 AM
Quoted: 15 Post(s)
The 3rd generation Altimas have electronic throttle control and thus do not have an IAC valve.
korner is offline
